[petsc-users] [PCGAMG + AGG + GMRES] Non-Exact Dirichlet Boundary Conditions
Karabelas, Elias (elias.karabelas@uni-graz.at) elias.karabelas at uni-graz.at
Thu Jul 7 06:03:09 CDT 2022
OK got it, well the "classical" option of GAMG removes this issue, and also HYPRE does that out-of-the box.
I would slightly disagree with non-exact DirichletBCs, especially in mechanics where I really assume a clamped node is clamped.
Best
Elias
Am 07.07.22 um 13:00 schrieb Mark Adams:
I think PCCOMPOSITE is overkill here.
First, I would only bother with this if this error is a problem. People use your method all the time and accept error at the scale of the solver tolerance.
But if you want the exact solution, well, you could just clobber the solution values after the solve if you have access to the Diri BC data on hand.
I was suggesting just creating a "Richardson/jacobi" solver, hardwire one iteration, use an initial guess and solve it.
Not great, because this would have to grab the diagonal. If you had the diagonal (eg, from the AMG smoother that does exist) then this would be pretty cheap (a residual calculation mostly).
On Thu, Jul 7, 2022 at 3:14 AM Karabelas, Elias (elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>) <elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>> wrote:
Hi Mark,
thanks for the answer, but I'm struggling to translate your suggestion into solver options.
From scrolling through the user manual I think this points towards PCCOMPOSITE.
However, the User Manual is not very precise with composite PCs, so how would I achieve this on top of my existing solver options?
Best regards
Elias
Am 06.07.22 um 16:41 schrieb Mark Adams:
And one iteration of undamped Jacobi after the solve should fix this.
On Wed, Jul 6, 2022 at 8:42 AM Karabelas, Elias (elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>) <elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>> wrote:
Dear Matt,
thanks for the fast response. That makes perfect sense to me.
Best regards
Elias
Am 06.07.22 um 14:35 schrieb Matthew Knepley:
On Wed, Jul 6, 2022 at 7:46 AM Karabelas, Elias (elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>) <elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>> wrote:
Dear all,
I don't know if this is a bug, but I observed that when using GMRES with AGG-PCGAMG as preconditioner Dirichlet boundary conditions don't seem to be exactly fulfilled.
My Matrix has zero rows and cols with 1 on the diagonal where I have dirichlet-bcs in my FE-mesh and I would expect that the eqs in this rows can be exactly fulfilled (as u_i = g_i) there.
I would not expect aggregation to be exact here, but only within the iteration tolerance. If instead you eliminate those variables, you can maintain algebraic exactness.
This is what we do in examples, like SNES ex56.
     Matt
However, when I solve A*x = b with the above solver I only get u_i = g_i + error in that part of the vector. Switching from pc_gamg_type agg to pc_gamg_type classical cures this problem, but the classical is not advertised in the user manual.
These are the options I'm currently using:
-ksp_type gmres
-ksp_pc_side right
-pc_type gamg
-pc_gamg_type agg [or classical]
-pc_gamg_sym_graph 1
-pc_gamg_square_graph 1
-pc_gamg_agg_nsmooths 1
-pc_gamg_threshold 0.01
-pc_mg_cycles v
Iteration counts are basically the same.
Best regards
Elias
Dr. Elias Karabelas
Research Associate
University of Graz
Institute of Mathematics and Scientific Computing
Heinrichstraße 36
A-8010 Graz
Austria
Phone: +43 316 380 8546
Email: elias.karabelas at uni-graz.at<mailto:elias.karabelas at uni-graz.at>
Web:  https://ccl.medunigraz.at/
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
Dr. Elias Karabelas
Research Associate
University of Graz
Heinrichstraße 36
A-8010 Graz
Austria
Dr. Elias Karabelas
Research Associate
University of Graz
Heinrichstraße 36
A-8010 Graz
Austria
Dr. Elias Karabelas
Research Associate
University of Graz
Heinrichstraße 36
A-8010 Graz
Austria
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220707/b6676a1a/attachment.html>
