[petsc-users] problem with spack instaler (trilinos link)
FOURMONT Axel
axel.fourmont at cea.fr
Tue Jan 25 08:05:17 CST 2022
Dear PETSc developers,
First of all thank you for your work!
I try to use the spack tool to install petsc with mumps: spack install petsc+mumps~hdf5 (with the good version for compilers). All is OK, PETSc works fine.
But now, I want acces to ML preconditioner, so I need install a PETSc version with trilinos: spack install petsc+mumps+trilinos~hdf5
The compilation fails (in the check phase), I notices 2 things:
petsc links on trilinos/lib64 but the directory path is lib
I make a symbolic link: ln -s trilinos/lib trilinos/lib64 to try solve it
Also there is an error with the definition of Zoltan_Create()
Can you help me please?
I attach the configure.log.
I use the last spack release v0.17.1 and
ubuntu 20.04 with gcc-10 gfortran-10, openmpi 4.0.3 from apt instaler
Axel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/891be65b/attachment-0001.html>
Type: text/x-log
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220125/891be65b/attachment-0001.bin>
