[petsc-users] Downloaded superlu_dist could not be used. Please check install in $PREFIX
Xiaoye S. Li xsli at lbl.gov
Tue Jan 18 16:50:28 CST 2022
There was a merge error in the master branch. I fixed it today. Not sure
whether that's causing your problem.   Can you try now?
Sherry
On Mon, Jan 17, 2022 at 11:55 AM Fande Kong <fdkong.jd at gmail.com> wrote:
> I am trying to port PETSc-3.16.3 to the MOOSE ecosystem. I got an error
> that PETSc could not build  superlu_dist.  The log file was attached.
> PETSc-3.15.x worked correctly in the same environment.
> Thanks,
> Fande
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220118/b53da3c8/attachment.html>
