[petsc-users] PETSc configuration error on macOS Monterey with Intel oneAPI
Danyang Su danyang.su at gmail.com
Thu Jan 13 00:01:08 CST 2022
Hi Samar,
Thanks for your suggestion. Unfortunately, it does not work. I checked the mpif90 wrapper and the option "-Wl,-flat_namespace” is present.
(base) ➜  bin ./mpif90 -show
ifort -I/Users/danyangsu/Soft/PETSc/petsc-3.16.3/macos-intel-dbg/include -Wl,-flat_namespace -Wl,-commons,use_dylibs -I/Users/danyangsu/Soft/PETSc/petsc-3.16.3/macos-intel-dbg/lib -L/Users/danyangsu/Soft/PETSc/petsc-3.16.3/macos-intel-dbg/lib -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi
Thanks anyway,
Danyang
From: Samar Khatiwala <samar.khatiwala at earth.ox.ac.uk>
Date: Wednesday, January 12, 2022 at 2:01 PM
To: Danyang Su <danyang.su at gmail.com>
Cc: PETSc <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] PETSc configuration error on macOS Monterey with Intel oneAPI
Hi Danyang,
I had trouble configuring PETSc on MacOS Monterey with ifort when using mpich (which I was building myself). I tracked it down to an errant "-Wl,-flat_namespace”
option in the mpif90 wrapper. I rebuilt mpich with the "--enable-two-level-namespace” configuration option and the problem went away. I don’t know if there’s a similar
issue with openmpi but you could check the corresponding mpif90 wrapper (mpif90 -show) whether "-Wl,-flat_namespace” is present or not. If so, perhaps passing
"--enable-two-level-namespace” to PETSc configure might fix the problem (although I don’t know how you would set this flag *just* for building openmpi).
Samar
On Jan 12, 2022, at 9:41 PM, Danyang Su <danyang.su at gmail.com> wrote:
Hi All,
I got an error in PETSc configuration on macOS Monterey with Intel oneAPI using the following options:
./configure --with-cc=icc --with-cxx=icpc --with-fc=ifort --with-blas-lapack-dir=/opt/intel/oneapi/mkl/2022.0.0/lib/ --with-debugging=1 PETSC_ARCH=macos-intel-dbg --download-mumps --download-parmetis --download-metis --download-hypre --download-superlu --download-hdf5=yes --download-openmpi
Error with downloaded OpenMPI: Cannot compile/link FC with /Users/danyangsu/Soft/PETSc/petsc-3.16.3/macos-intel-dbg/bin/mpif90.
Any suggestions for that?
There is no problem if I use GNU compiler and MPICH.
Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220112/9557b34b/attachment.html>
