[petsc-users] PETSc configuration error on macOS Monterey with Intel oneAPI
    Samar Khatiwala
    samar.khatiwala at earth.ox.ac.uk
    Wed Jan 12 16:01:18 CST 2022
Hi Danyang,
I had trouble configuring PETSc on MacOS Monterey with ifort when using mpich (which I was building myself). I tracked it down to an errant "-Wl,-flat_namespace”
option in the mpif90 wrapper. I rebuilt mpich with the "--enable-two-level-namespace” configuration option and the problem went away. I don’t know if there’s a similar
issue with openmpi but you could check the corresponding mpif90 wrapper (mpif90 -show) whether "-Wl,-flat_namespace” is present or not. If so, perhaps passing
"--enable-two-level-namespace” to PETSc configure might fix the problem (although I don’t know how you would set this flag *just* for building openmpi).
Samar
> On Jan 12, 2022, at 9:41 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi All,
> I got an error in PETSc configuration on macOS Monterey with Intel oneAPI using the following options:
> ./configure --with-cc=icc --with-cxx=icpc --with-fc=ifort --with-blas-lapack-dir=/opt/intel/oneapi/mkl/2022.0.0/lib/ --with-debugging=1 PETSC_ARCH=macos-intel-dbg --download-mumps --download-parmetis --download-metis --download-hypre --download-superlu --download-hdf5=yes --download-openmpi
> Error with downloaded OpenMPI: Cannot compile/link FC with /Users/danyangsu/Soft/PETSc/petsc-3.16.3/macos-intel-dbg/bin/mpif90.
> Any suggestions for that?
> There is no problem if I use GNU compiler and MPICH.
> Thanks,
> Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220112/341ba42f/attachment.html>
