[petsc-users] Fluid-Structure interaction with multiple DMPlex
    Thibault Bridel-Bertomeu
    thibault.bridelbertomeu at gmail.com
    Sun Jan  9 10:32:57 CST 2022
Le dim. 9 janv. 2022 à 17:24, Matthew Knepley <knepley at gmail.com> a écrit :
> On Sun, Jan 9, 2022 at 11:16 AM Thibault Bridel-Bertomeu <
> thibault.bridelbertomeu at gmail.com> wrote:
>> Le dim. 9 janv. 2022 à 17:08, Matthew Knepley <knepley at gmail.com> a
>> écrit :
>>> On Sun, Jan 9, 2022 at 10:53 AM Thibault Bridel-Bertomeu <
>>>> Le dim. 9 janv. 2022 à 15:38, Matthew Knepley <knepley at gmail.com> a
>>>> écrit :
>>>>> On Sun, Jan 9, 2022 at 7:49 AM Thibault Bridel-Bertomeu <
>>>>>> Le dim. 9 janv. 2022 à 13:05, Matthew Knepley <knepley at gmail.com> a
>>>>>> écrit :
>>>>>>> On Sat, Jan 8, 2022 at 2:13 PM Thibault Bridel-Bertomeu <
>>>>>>>> However if you use IMEX for strong coupling of the two physics
>>>>>>>> solved in each field, then it means you need to write a single set of PDEs
>>>>>>>> that covers everything, don’t you ?
>>>>>>>> If I want to solve Euler equations in one PetscDS and heat equation
>>>>>>>> in the other one, then I need to write a global set of equations to use the
>>>>>>>> IMEX TS , right ?
>>>>>>> The way I think about it. You would have explicit terms for Euler,
>>>>>>> and they would also be confined to one part of the domain, but that just
>>>>>>> impacts how you do the residual integral. You do assemble a combined
>>>>>>> residual for all dogs, however, which I think is what you mean.
>>>>>> Hmm I'm not quite sure yet, probably because I haven't really started
>>>>>> implementing it and I am not familiar with finite elements in PETSc.
>>>>>> The way I see it is that a TS expects to be solving dU/dt = F, that's
>>>>>> why I'm imagining that even with two domains with two different physics,
>>>>>> one has to write the problem under the previous form. And when it comes to
>>>>>> a FVM version of Euler + a FEM version of heat eqn, I'm not quite certain
>>>>>> how to write it like that.
>>>>>> Am I making any sense ? ô_o
>>>>> Oh, if you have boundary communication, then formulating it as one
>>>>> system is difficult because different cells in supposedly the same DS would
>>>>> have different unknowns, yes. IB solves this by defining the other
>>>>> fields over the whole of each subdomain. Schwarz methods make two different
>>>>> problems and then pass values with what I call an "auxiliary field".
>>>>> You are right that you have to do something.
>>>> Let's imagine that we read in a Gmsh mesh into a DMPlex.
>>>> That Gmsh mesh has two physical volumes so the DMPlex will a priori
>>>> show two labels and therefore (?) two fields, meaning we can work with two
>>>> SubDMs.
>>>> Each SubDM basically matches a region of the whole mesh in this case.
>>>> Now each SubDM can have its own DS and we can also attribute each DM to
>>>> a TS.
>>>> We can therefore solve the two problems, say one for fluid dynamics the
>>>> other for heat eqn.
>>>> The only thing I am not sure about (actually I haven't coded anything
>>>> yet so I'm not sure of anything but ...) is the following.
>>>> The two SubDMs come originally from the same DM right. Say we work in
>>>> 3D, then the two SubDM must share a layer of triangles (and the segments
>>>> and vertices that go along with them). That layer of triangles exist in
>>>> both SubDM and is a boundary in both SubDM.
>>>> How do I tell, for instance, the fluid SubDM that the information it
>>>> needs on that layer of triangles comes from the other SubDM ? And vice
>>>> versa ? Is it possible to create two SubDMs from the same DM that somehow
>>>> still know each other after the creation ?
>>>> Example 23 from SNES does not do that kind of thing right ? The "top"
>>>> and "bottom" pieces are quite independent or am I misunderstanding sth ?
>>> The way I see it working is that you compose the maps from the original
>>> space to each subDM on the boundary. Then, when you get one solution, you
>>> can map it to points on the boundary of the other solution, which you use
>>> as an auxiliary field.
>> Okay yes, I get what you mean. Is there a method in PETSc to do such
>> things ? Does it have to do with IS ?
> Yes, we can do it. It is just IS manipulation.
Tagging that layer of triangles as a physical surface in Gmsh can help
later because it will create another label in the DMPlex, right ?
Then one could maybe rely on DMGetLabelIdIS ?
Thank you Matt as usual for your precious help ! ;)
Thibault
>   Thanks,
>     Matt
>> Thanks !
>> Thibault
>>>   Thanks,
>>>      Matt
>>>> Thanks !!
>>>> Thibault
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Thibault
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>> Thanks,
>>>>>>>> Thibault
>>>>>>>> Le sam. 8 janv. 2022 à 20:00, Matthew Knepley <knepley at gmail.com>
>>>>>>>> a écrit :
>>>>>>>>> On Sat, Jan 8, 2022 at 1:30 PM Thibault Bridel-Bertomeu <
>>>>>>>>>> Yes I was wondering about different time steps as well because
>>>>>>>>>> usually implicit integration moves much faster.
>>>>>>>>>> But if it not implemented, then maybe going the « weak coupling »
>>>>>>>>>> road with a sub-DM is the way.
>>>>>>>>>> Can I ask how you proceed in the rocket engine code you are
>>>>>>>>>> writing ? IMEX ?
>>>>>>>>> Right now it is IMEX, but we are explicitly substepping particles.
>>>>>>>>> Not sure what the final thing will be.
>>>>>>>>>   Thanks,
>>>>>>>>>     Matt
>>>>>>>>>> Thibault
>>>>>>>>>> Le sam. 8 janv. 2022 à 19:22, Matthew Knepley <knepley at gmail.com>
>>>>>>>>>> a écrit :
>>>>>>>>>>> I do not know how. Right now, composable TS does not work all
>>>>>>>>>>> the way.
>>>>>>>>>>>   Matt
>>>>>>>>>>> On Sat, Jan 8, 2022 at 1:03 PM Mark Adams <mfadams at lbl.gov>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Can you subcycle with IMEX?
>>>>>>>>>>>> On Sat, Jan 8, 2022 at 10:58 AM Matthew Knepley <
>>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>>> On Sat, Jan 8, 2022 at 3:05 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 19:45, Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>> thibault.bridelbertomeu at gmail.com> a écrit :
>>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 19:23, Matthew Knepley <
>>>>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 12:58 PM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 14:54, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 8:52 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>>>>>>> Hi Matthew,
>>>>>>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 14:44, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 5:46 AM Thibault Bridel-Bertomeu
>>>>>>>>>>>>>>>>>>>> <thibault.bridelbertomeu at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>>>>>> First of, happy new year everyone !! All the best !
>>>>>>>>>>>>>>>>>>>> Happy New Year!
>>>>>>>>>>>>>>>>>>>>> I am starting to draft a new project that will be
>>>>>>>>>>>>>>>>>>>>> about fluid-structure interaction: in particular, the idea is to compute
>>>>>>>>>>>>>>>>>>>>> the Navier-Stokes (or Euler nevermind) flow around an object and _at the
>>>>>>>>>>>>>>>>>>>>> same time_ compute the heat equation inside the object.
>>>>>>>>>>>>>>>>>>>>> So basically, I am thinking a mesh of the fluid and a
>>>>>>>>>>>>>>>>>>>>> mesh of the object, both meshes being linked at the fluid - solid interface.
>>>>>>>>>>>>>>>>>>>> First question: Are these meshes intended to match on
>>>>>>>>>>>>>>>>>>>> the interface? If not, this sounds like overset grids or immersed
>>>>>>>>>>>>>>>>>>>> boundary/interface methods. In this case, more than one mesh makes sense to
>>>>>>>>>>>>>>>>>>>> me. If they are intended to match, then I would advocate a single mesh with
>>>>>>>>>>>>>>>>>>>> multiple problems defined on it. I have experimented with this, for example
>>>>>>>>>>>>>>>>>>>> see SNES ex23 where I have a field in only part of the domain. I have a
>>>>>>>>>>>>>>>>>>>> large project to do exactly this in a rocket engine now.
>>>>>>>>>>>>>>>>>>> Yes the way I see it is more of a single mesh with two
>>>>>>>>>>>>>>>>>>> distinct regions to distinguish between the fluid and the solid. I was
>>>>>>>>>>>>>>>>>>> talking about two meshes to try and explain my vision but it seems like it
>>>>>>>>>>>>>>>>>>> was unclear.
>>>>>>>>>>>>>>>>>>> Imagine if you wish a rectangular box with a sphere
>>>>>>>>>>>>>>>>>>> inclusion: the sphere would be tagged as a solid and the rest of the domain
>>>>>>>>>>>>>>>>>>> as fluid. Using Gmsh volumes for instance.
>>>>>>>>>>>>>>>>>>> Ill check out the SNES example ! Thanks !
>>>>>>>>>>>>>>>>>>>>> First (Matthew maybe ?) do you think it is something
>>>>>>>>>>>>>>>>>>>>> that could be done using two DMPlex's that would somehow be spawned from
>>>>>>>>>>>>>>>>>>>>> reading a Gmsh mesh with two volumes ?
>>>>>>>>>>>>>>>>>>>> You can take a mesh and filter out part of it with
>>>>>>>>>>>>>>>>>>>> DMPlexFilter(). That is not used much so I may have to fix it to do what
>>>>>>>>>>>>>>>>>>>> you want, but that should be easy.
>>>>>>>>>>>>>>>>>>>>> And on one DMPlex we would have finite volume for the
>>>>>>>>>>>>>>>>>>>>> fluid, on the other finite elements for the heat eqn ?
>>>>>>>>>>>>>>>>>>>> I have done this exact thing on a single mesh. It
>>>>>>>>>>>>>>>>>>>> should be no harder on two meshes if you go that route.
>>>>>>>>>>>>>>>>>>>>> Second, is it something that anyone in the community
>>>>>>>>>>>>>>>>>>>>> has ever imagined doing with PETSc DMPlex's ?
>>>>>>>>>>>>>>>>>>>> Yes, I had a combined FV+FEM simulation of magma
>>>>>>>>>>>>>>>>>>>> dynamics (I should make it an example), and currently we are doing FVM+FEM
>>>>>>>>>>>>>>>>>>>> for simulation of a rocket engine.
>>>>>>>>>>>>>>>>>>> Wow so it seems like it’s the exact same thing I would
>>>>>>>>>>>>>>>>>>> like to achieve as the rocket engine example.
>>>>>>>>>>>>>>>>>>> So you have a single mesh and two regions tagged
>>>>>>>>>>>>>>>>>>> differently, and you use the DmPlexFilter to solve FVM and FEM separately ?
>>>>>>>>>>>>>>>>>> With a single mesh, you do not even need DMPlexFilter.
>>>>>>>>>>>>>>>>>> You just use the labels that Gmsh gives you. I think we should be able to
>>>>>>>>>>>>>>>>>> get it going in a straightforward way.
>>>>>>>>>>>>>>>>> Ok then ! Thanks ! I’ll give it a shot and see what
>>>>>>>>>>>>>>>>> happens !
>>>>>>>>>>>>>>>>> Setting up the FVM and FEM discretizations will pass by
>>>>>>>>>>>>>>>>> DMSetField right ? With a single mesh tagged with two different regions, it
>>>>>>>>>>>>>>>>> should show up as two fields, is that correct ?
>>>>>>>>>>>>>>>> Yes, the idea is as follows. Each field also has a label
>>>>>>>>>>>>>>>> argument that is the support of the field in the domain. Then we create
>>>>>>>>>>>>>>>> PetscDS objects for each
>>>>>>>>>>>>>>>> separate set of overlapping fields. The current algorithm
>>>>>>>>>>>>>>>> is not complete I think, so let me know if this step fails.
>>>>>>>>>>>>>>> Ok, thanks.
>>>>>>>>>>>>>>> I’ll let you know and share snippets when I have something
>>>>>>>>>>>>>>> started !
>>>>>>>>>>>>>>> Talk soon ! Thanks !
>>>>>>>>>>>>>> Hi Matthew,
>>>>>>>>>>>>>> I thought about a little something else : what about setting
>>>>>>>>>>>>>> two different TS, one for each field of the DM ? Most probably the fluid
>>>>>>>>>>>>>> part would be solved with an explicit time stepping whereas the solid part
>>>>>>>>>>>>>> with the heat equation would benefit from implicit time stepping. TSSetDM
>>>>>>>>>>>>>> does not allow a field specification, is there a way to hack that so that
>>>>>>>>>>>>>> each field has its own TS ?
>>>>>>>>>>>>> I see at least two options here:
>>>>>>>>>>>>> 1. Split the problems:
>>>>>>>>>>>>>     You can use DMCreateSubDM() to split off part of a problem
>>>>>>>>>>>>> and use a solver on that. I have done this for problems with weak coupling.
>>>>>>>>>>>>> 2. Use IMEX
>>>>>>>>>>>>>     For strong coupling, I have used the IMEX TSes in PETSc.
>>>>>>>>>>>>> You put the explicit terms in the RHS, and the implicit in the IFunction.
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>>> Thanks !
>>>>>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>>>>> As I said it is very prospective, I just wanted to
>>>>>>>>>>>>>>>>>>>>> have your opinion !!
>>>>>>>>>>>>>>>>>>>>> Thanks very much in advance everyone !!
>>>>>>>>>>>>>>>>>>>>> Cheers,
>>>>>>>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>>>>>>>> Tel.: (+33)557046924
>>>>>>>>>>>>>>>>>>> Mob.: (+33)611025322
>>>>>>>>>>>>>>>>>>> Mail: thibault.bridelbertomeu at gmail.com
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>> Research Engineer
>>>>>>>>>> CEA/CESTA
>>>>>>>>>> 33114 LE BARP
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> Eng, MSc, PhD
>>>>>>>> Research Engineer
>>>>>>>> CEA/CESTA
>>>>>>>> 33114 LE BARP
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220109/77a945a2/attachment-0001.html>
