[petsc-users] Fluid-Structure interaction with multiple DMPlex
    Matthew Knepley
    knepley at gmail.com
    Sun Jan  9 10:24:13 CST 2022
On Sun, Jan 9, 2022 at 11:16 AM Thibault Bridel-Bertomeu <
thibault.bridelbertomeu at gmail.com> wrote:
> Le dim. 9 janv. 2022 à 17:08, Matthew Knepley <knepley at gmail.com> a
> écrit :
>> On Sun, Jan 9, 2022 at 10:53 AM Thibault Bridel-Bertomeu <
>>> Le dim. 9 janv. 2022 à 15:38, Matthew Knepley <knepley at gmail.com> a
>>> écrit :
>>>> On Sun, Jan 9, 2022 at 7:49 AM Thibault Bridel-Bertomeu <
>>>>> Le dim. 9 janv. 2022 à 13:05, Matthew Knepley <knepley at gmail.com> a
>>>>> écrit :
>>>>>> On Sat, Jan 8, 2022 at 2:13 PM Thibault Bridel-Bertomeu <
>>>>>>> However if you use IMEX for strong coupling of the two physics
>>>>>>> solved in each field, then it means you need to write a single set of PDEs
>>>>>>> that covers everything, don’t you ?
>>>>>>> If I want to solve Euler equations in one PetscDS and heat equation
>>>>>>> in the other one, then I need to write a global set of equations to use the
>>>>>>> IMEX TS , right ?
>>>>>> The way I think about it. You would have explicit terms for Euler,
>>>>>> and they would also be confined to one part of the domain, but that just
>>>>>> impacts how you do the residual integral. You do assemble a combined
>>>>>> residual for all dogs, however, which I think is what you mean.
>>>>> Hmm I'm not quite sure yet, probably because I haven't really started
>>>>> implementing it and I am not familiar with finite elements in PETSc.
>>>>> The way I see it is that a TS expects to be solving dU/dt = F, that's
>>>>> why I'm imagining that even with two domains with two different physics,
>>>>> one has to write the problem under the previous form. And when it comes to
>>>>> a FVM version of Euler + a FEM version of heat eqn, I'm not quite certain
>>>>> how to write it like that.
>>>>> Am I making any sense ? ô_o
>>>> Oh, if you have boundary communication, then formulating it as one
>>>> system is difficult because different cells in supposedly the same DS would
>>>> have different unknowns, yes. IB solves this by defining the other
>>>> fields over the whole of each subdomain. Schwarz methods make two different
>>>> problems and then pass values with what I call an "auxiliary field".
>>>> You are right that you have to do something.
>>> Let's imagine that we read in a Gmsh mesh into a DMPlex.
>>> That Gmsh mesh has two physical volumes so the DMPlex will a priori show
>>> two labels and therefore (?) two fields, meaning we can work with two
>>> SubDMs.
>>> Each SubDM basically matches a region of the whole mesh in this case.
>>> Now each SubDM can have its own DS and we can also attribute each DM to
>>> a TS.
>>> We can therefore solve the two problems, say one for fluid dynamics the
>>> other for heat eqn.
>>> The only thing I am not sure about (actually I haven't coded anything
>>> yet so I'm not sure of anything but ...) is the following.
>>> The two SubDMs come originally from the same DM right. Say we work in
>>> 3D, then the two SubDM must share a layer of triangles (and the segments
>>> and vertices that go along with them). That layer of triangles exist in
>>> both SubDM and is a boundary in both SubDM.
>>> How do I tell, for instance, the fluid SubDM that the information it
>>> needs on that layer of triangles comes from the other SubDM ? And vice
>>> versa ? Is it possible to create two SubDMs from the same DM that somehow
>>> still know each other after the creation ?
>>> Example 23 from SNES does not do that kind of thing right ? The "top"
>>> and "bottom" pieces are quite independent or am I misunderstanding sth ?
>> The way I see it working is that you compose the maps from the original
>> space to each subDM on the boundary. Then, when you get one solution, you
>> can map it to points on the boundary of the other solution, which you use
>> as an auxiliary field.
> Okay yes, I get what you mean. Is there a method in PETSc to do such
> things ? Does it have to do with IS ?
Yes, we can do it. It is just IS manipulation.
    Matt
> Thanks !
> Thibault
>>   Thanks,
>>      Matt
>>> Thanks !!
>>> Thibault
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Thibault
>>>>>>   Thanks,
>>>>>>     Matt
>>>>>>> Thanks,
>>>>>>> Thibault
>>>>>>> Le sam. 8 janv. 2022 à 20:00, Matthew Knepley <knepley at gmail.com> a
>>>>>>> écrit :
>>>>>>>> On Sat, Jan 8, 2022 at 1:30 PM Thibault Bridel-Bertomeu <
>>>>>>>>> Yes I was wondering about different time steps as well because
>>>>>>>>> usually implicit integration moves much faster.
>>>>>>>>> But if it not implemented, then maybe going the « weak coupling »
>>>>>>>>> road with a sub-DM is the way.
>>>>>>>>> Can I ask how you proceed in the rocket engine code you are
>>>>>>>>> writing ? IMEX ?
>>>>>>>> Right now it is IMEX, but we are explicitly substepping particles.
>>>>>>>> Not sure what the final thing will be.
>>>>>>>>   Thanks,
>>>>>>>>     Matt
>>>>>>>>> Thibault
>>>>>>>>> Le sam. 8 janv. 2022 à 19:22, Matthew Knepley <knepley at gmail.com>
>>>>>>>>> a écrit :
>>>>>>>>>> I do not know how. Right now, composable TS does not work all the
>>>>>>>>>> way.
>>>>>>>>>>   Matt
>>>>>>>>>> On Sat, Jan 8, 2022 at 1:03 PM Mark Adams <mfadams at lbl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>>> Can you subcycle with IMEX?
>>>>>>>>>>> On Sat, Jan 8, 2022 at 10:58 AM Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Sat, Jan 8, 2022 at 3:05 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 19:45, Thibault Bridel-Bertomeu <
>>>>>>>>>>>>> thibault.bridelbertomeu at gmail.com> a écrit :
>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 19:23, Matthew Knepley <
>>>>>>>>>>>>>> knepley at gmail.com> a écrit :
>>>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 12:58 PM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 14:54, Matthew Knepley <
>>>>>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 8:52 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>>>>>> Hi Matthew,
>>>>>>>>>>>>>>>>>> Le ven. 7 janv. 2022 à 14:44, Matthew Knepley <
>>>>>>>>>>>>>>>>>>> On Fri, Jan 7, 2022 at 5:46 AM Thibault Bridel-Bertomeu <
>>>>>>>>>>>>>>>>>>>> Dear all,
>>>>>>>>>>>>>>>>>>>> First of, happy new year everyone !! All the best !
>>>>>>>>>>>>>>>>>>> Happy New Year!
>>>>>>>>>>>>>>>>>>>> I am starting to draft a new project that will be about
>>>>>>>>>>>>>>>>>>>> fluid-structure interaction: in particular, the idea is to compute the
>>>>>>>>>>>>>>>>>>>> Navier-Stokes (or Euler nevermind) flow around an object and _at the same
>>>>>>>>>>>>>>>>>>>> time_ compute the heat equation inside the object.
>>>>>>>>>>>>>>>>>>>> So basically, I am thinking a mesh of the fluid and a
>>>>>>>>>>>>>>>>>>>> mesh of the object, both meshes being linked at the fluid - solid interface.
>>>>>>>>>>>>>>>>>>> First question: Are these meshes intended to match on
>>>>>>>>>>>>>>>>>>> the interface? If not, this sounds like overset grids or immersed
>>>>>>>>>>>>>>>>>>> boundary/interface methods. In this case, more than one mesh makes sense to
>>>>>>>>>>>>>>>>>>> me. If they are intended to match, then I would advocate a single mesh with
>>>>>>>>>>>>>>>>>>> multiple problems defined on it. I have experimented with this, for example
>>>>>>>>>>>>>>>>>>> see SNES ex23 where I have a field in only part of the domain. I have a
>>>>>>>>>>>>>>>>>>> large project to do exactly this in a rocket engine now.
>>>>>>>>>>>>>>>>>> Yes the way I see it is more of a single mesh with two
>>>>>>>>>>>>>>>>>> distinct regions to distinguish between the fluid and the solid. I was
>>>>>>>>>>>>>>>>>> talking about two meshes to try and explain my vision but it seems like it
>>>>>>>>>>>>>>>>>> was unclear.
>>>>>>>>>>>>>>>>>> Imagine if you wish a rectangular box with a sphere
>>>>>>>>>>>>>>>>>> inclusion: the sphere would be tagged as a solid and the rest of the domain
>>>>>>>>>>>>>>>>>> as fluid. Using Gmsh volumes for instance.
>>>>>>>>>>>>>>>>>> Ill check out the SNES example ! Thanks !
>>>>>>>>>>>>>>>>>>>> First (Matthew maybe ?) do you think it is something
>>>>>>>>>>>>>>>>>>>> that could be done using two DMPlex's that would somehow be spawned from
>>>>>>>>>>>>>>>>>>>> reading a Gmsh mesh with two volumes ?
>>>>>>>>>>>>>>>>>>> You can take a mesh and filter out part of it with
>>>>>>>>>>>>>>>>>>> DMPlexFilter(). That is not used much so I may have to fix it to do what
>>>>>>>>>>>>>>>>>>> you want, but that should be easy.
>>>>>>>>>>>>>>>>>>>> And on one DMPlex we would have finite volume for the
>>>>>>>>>>>>>>>>>>>> fluid, on the other finite elements for the heat eqn ?
>>>>>>>>>>>>>>>>>>> I have done this exact thing on a single mesh. It should
>>>>>>>>>>>>>>>>>>> be no harder on two meshes if you go that route.
>>>>>>>>>>>>>>>>>>>> Second, is it something that anyone in the community
>>>>>>>>>>>>>>>>>>>> has ever imagined doing with PETSc DMPlex's ?
>>>>>>>>>>>>>>>>>>> Yes, I had a combined FV+FEM simulation of magma
>>>>>>>>>>>>>>>>>>> dynamics (I should make it an example), and currently we are doing FVM+FEM
>>>>>>>>>>>>>>>>>>> for simulation of a rocket engine.
>>>>>>>>>>>>>>>>>> Wow so it seems like it’s the exact same thing I would
>>>>>>>>>>>>>>>>>> like to achieve as the rocket engine example.
>>>>>>>>>>>>>>>>>> So you have a single mesh and two regions tagged
>>>>>>>>>>>>>>>>>> differently, and you use the DmPlexFilter to solve FVM and FEM separately ?
>>>>>>>>>>>>>>>>> With a single mesh, you do not even need DMPlexFilter. You
>>>>>>>>>>>>>>>>> just use the labels that Gmsh gives you. I think we should be able to get
>>>>>>>>>>>>>>>>> it going in a straightforward way.
>>>>>>>>>>>>>>>> Ok then ! Thanks ! I’ll give it a shot and see what happens
>>>>>>>>>>>>>>>> Setting up the FVM and FEM discretizations will pass by
>>>>>>>>>>>>>>>> DMSetField right ? With a single mesh tagged with two different regions, it
>>>>>>>>>>>>>>>> should show up as two fields, is that correct ?
>>>>>>>>>>>>>>> Yes, the idea is as follows. Each field also has a label
>>>>>>>>>>>>>>> argument that is the support of the field in the domain. Then we create
>>>>>>>>>>>>>>> PetscDS objects for each
>>>>>>>>>>>>>>> separate set of overlapping fields. The current algorithm is
>>>>>>>>>>>>>>> not complete I think, so let me know if this step fails.
>>>>>>>>>>>>>> Ok, thanks.
>>>>>>>>>>>>>> I’ll let you know and share snippets when I have something
>>>>>>>>>>>>>> started !
>>>>>>>>>>>>>> Talk soon ! Thanks !
>>>>>>>>>>>>> Hi Matthew,
>>>>>>>>>>>>> I thought about a little something else : what about setting
>>>>>>>>>>>>> two different TS, one for each field of the DM ? Most probably the fluid
>>>>>>>>>>>>> part would be solved with an explicit time stepping whereas the solid part
>>>>>>>>>>>>> with the heat equation would benefit from implicit time stepping. TSSetDM
>>>>>>>>>>>>> does not allow a field specification, is there a way to hack that so that
>>>>>>>>>>>>> each field has its own TS ?
>>>>>>>>>>>> I see at least two options here:
>>>>>>>>>>>> 1. Split the problems:
>>>>>>>>>>>>     You can use DMCreateSubDM() to split off part of a problem
>>>>>>>>>>>> and use a solver on that. I have done this for problems with weak coupling.
>>>>>>>>>>>> 2. Use IMEX
>>>>>>>>>>>>     For strong coupling, I have used the IMEX TSes in PETSc.
>>>>>>>>>>>> You put the explicit terms in the RHS, and the implicit in the IFunction.
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>> Thanks !
>>>>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>>>> As I said it is very prospective, I just wanted to have
>>>>>>>>>>>>>>>>>>>> your opinion !!
>>>>>>>>>>>>>>>>>>>> Thanks very much in advance everyone !!
>>>>>>>>>>>>>>>>>>>> Cheers,
>>>>>>>>>>>>>>>>>>>> Thibault
>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>>>>>>> Tel.: (+33)557046924
>>>>>>>>>>>>>>>>>> Mob.: (+33)611025322
>>>>>>>>>>>>>>>>>> Mail: thibault.bridelbertomeu at gmail.com
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>>> Eng, MSc, PhD
>>>>>>>>>>>>> Research Engineer
>>>>>>>>>>>>> CEA/CESTA
>>>>>>>>>>>>> 33114 LE BARP
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> Eng, MSc, PhD
>>>>>>>>> Research Engineer
>>>>>>>>> CEA/CESTA
>>>>>>>>> 33114 LE BARP
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> Eng, MSc, PhD
>>>>>>> Research Engineer
>>>>>>> CEA/CESTA
>>>>>>> 33114 LE BARP
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220109/2c6f985e/attachment-0001.html>
