[petsc-users] set MUMPS OOC_TMPDIR
Sam Guo sam.guo at cd-adapco.com
Mon Feb 28 14:42:05 CST 2022
Done. Thanks.
On Mon, Feb 28, 2022 at 12:29 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 28, 2022 at 3:19 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Great. Can you send me the patch so I can apply it to my local branch?
>> Then I will create an issue for the next release. How do I create an issue?
>> When is the next release?
> You make the issue so we remember to write the code:
>   https://gitlab.com/petsc/petsc/-/issues?sort=created_date&state=opened
>   Thanks,
>       Matt
>> On Mon, Feb 28, 2022 at 12:14 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Feb 28, 2022 at 3:10 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Hi Matt,
>>>>    I love to have a get/set function interface.
>>> We can help you write the code, or you can create an Issue and we will
>>> write it as soon as we can.
>>>   Thanks,
>>>      MAtt
>>>> Thanks,
>>>> Sam
>>>> On Mon, Feb 28, 2022 at 11:43 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> No we do not have that right now. We would be happy to accept a
>>>>> contribution with a get/set function interface if you need that.
>>>>>   Thanks,
>>>>>      Matt
>>>>> On Mon, Feb 28, 2022 at 2:24 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>> Typo correction: It seems there is no such an API.
>>>>>> On Mon, Feb 28, 2022 at 11:22 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>> wrote:
>>>>>>> Dear PETSc dev team,
>>>>>>>    I would like to set MUMPS OOC_TMPDIR programmatically on fly
>>>>>>> (instead of statically using PetscOptionsString
>>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PetscOptionsString.html#PetscOptionsString>
>>>>>>> ("-mat_mumps_ooc_tmpdir", "out of core directory", "None",
>>>>>>> mumps->id.ooc_tmpdir, mumps->id.ooc_tmpdir, sizeof(mumps->id.ooc_tmpdir),
>>>>>>> NULL);). It seems there is such an API, am I correct?
>>>>>>> Thanks,
>>>>>>> Sam
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220228/e46637de/attachment.html>
