[petsc-users] set MUMPS OOC_TMPDIR
Mon Feb 28 14:29:09 CST 2022
On Mon, Feb 28, 2022 at 3:19 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Great. Can you send me the patch so I can apply it to my local branch?
> Then I will create an issue for the next release. How do I create an issue?
> When is the next release?
You make the issue so we remember to write the code:
  https://gitlab.com/petsc/petsc/-/issues?sort=created_date&state=opened
      Matt
> On Mon, Feb 28, 2022 at 12:14 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Feb 28, 2022 at 3:10 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> Hi Matt,
>>>    I love to have a get/set function interface.
>> We can help you write the code, or you can create an Issue and we will
>> write it as soon as we can.
>>   Thanks,
>>      MAtt
>>> Thanks,
>>> Sam
>>> On Mon, Feb 28, 2022 at 11:43 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> No we do not have that right now. We would be happy to accept a
>>>> contribution with a get/set function interface if you need that.
>>>>   Thanks,
>>>>      Matt
>>>> On Mon, Feb 28, 2022 at 2:24 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Typo correction: It seems there is no such an API.
>>>>> On Mon, Feb 28, 2022 at 11:22 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>> wrote:
>>>>>> Dear PETSc dev team,
>>>>>>    I would like to set MUMPS OOC_TMPDIR programmatically on fly
>>>>>> (instead of statically using PetscOptionsString
>>>>>> <https://petsc.org/main/docs/manualpages/Sys/PetscOptionsString.html#PetscOptionsString>
>>>>>> ("-mat_mumps_ooc_tmpdir", "out of core directory", "None",
>>>>>> mumps->id.ooc_tmpdir, mumps->id.ooc_tmpdir, sizeof(mumps->id.ooc_tmpdir),
>>>>>> NULL);). It seems there is such an API, am I correct?
>>>>>> Thanks,
>>>>>> Sam
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220228/18e511ca/attachment-0001.html>
