[petsc-users] Questions regarding nested field split
Fri Feb 25 13:53:26 CST 2022
On Fri, Feb 25, 2022 at 2:40 PM Sundar Namala <solomon.sundar.n at gmail.com>
wrote:
> Hi, I am currently using fieldsplit and I am creating the fields using
> ISCreateGeneral.programming is being carried out in FORTRAN. I have a
> couple of questions regarding fieldsplit in parallel.
> Do we need to create the index list of all the fields separately for each
> processor?
> For example, say I have 3 fields and the indices for field_0 is 0-99,
> field_1 is 100-299 and field_2 is 300-349. In case of 2 processors do I
> have to specify the indices for the first processor as field_0 is 0-99,
> field_1 is 100-174 and field_2 is null. On the second processor field_0 is
> null, field_1 is 175-299 and field_2 is 300-349.
Yes, each process specifies its indices independently (and for each field).
> my second question is if the indices need to be listed separately how do
> you assign the null index list using ISCreateGeneral.
You can use an IS with size 0.
     Matt
> Thanks,
> Sundar.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220225/5357393f/attachment.html>
