[petsc-users] Configuring with CMake
Tue Feb 22 10:15:13 CST 2022
Perhaps the easy fix is to build PETSc as shared libraries. [this is the default anyway]
However wrt pkgconfig:
$ cat arch-linux-c-debug/lib/pkgconfig/petsc.pc
prefix=/home/balay/petsc/arch-linux-c-debug
exec_prefix=${prefix}
includedir=${prefix}/include
libdir=${prefix}/lib
ccompiler=mpicc
cflags_extra=-fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0
cflags_dep=-MMD -MP
ldflag_rpath=-Wl,-rpath,
cxxcompiler=mpicxx
cxxflags_extra=-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g -O0  -std=gnu++17 -fPIC
fcompiler=mpif90
fflags_extra=-fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O0
Description: Library to solve ODEs and algebraic equations
Version: 3.16.99
Cflags:   -I${includedir} -I/home/balay/petsc/include
Libs: -L${libdir} -lpetsc
Libs.private: -L/home/balay/soft/mpich-3.4.2/lib -L/usr/lib/gcc/x86_64-redhat-linux/11 -llapack -lblas -lm -lX11 -lstdc++ -ldl -lmpifort -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
i.e 'Libs' provides the petsc library [usable when built as shared] - and 'Libs.private' provides all the dependencies [that are required in a static build]
Satish
On Tue, 22 Feb 2022, Palmer, Bruce J via petsc-users wrote:
> Hi,
> We recently switched the CMake configuration on our GridPACK application to use the PkgConfig utility instead of Jeb Brown’s FindPETSc.cmake module. This seems to work on a number of platforms but it is failing to link on others. It appears that the build cannot find the LAPACK and BLAS libraries. The PETSc library I’m linking to (v3.16.3) was configured with -download-f2cblaslapack so it should have these libraries, but when I try and link one of the test applications in GridPACK I get the errors
> /share/apps/gcc/6.1.0/bin/g++ -pthread -g -rdynamic CMakeFiles/greetings.dir/test/greetings.cpp.o -o greetings  -Wl,-rpath,/qfs/projects/ops/rh6/openmpi/3.0.1/gcc/6.1.0/lib ../math/libgridpack_math.a libgridpack_parallel.a ../timer/libgridpack_timer.a ../environment/libgridpack_environment.a ../math/libgridpack_math.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_mpi.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_serialization.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_random.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_filesystem.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_system.a /pic/projects/gridpack/software/ga-5.7/build_pr/lib/libga++.a /pic/projects/gridpack/software/ga-5.7/build_pr/lib/libga.a /pic/projects/gridpack/software/ga-5.7/build_pr/lib/libarmci.a -lrt /usr/lib64/librt.so /usr/lib64/libdl.so /qfs/projects/ops/rh6/openmpi/3.0.1/gcc/6.1.0/lib/libmpi.so ../timer/libgridpack_timer.a libgri
 dpack_pa
 rallel.a ../configuration/libgridpack_configuration.a /pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a
> /pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(zstart.o): In function `petscinitializef_':
> /pic/projects/gridpack/software/petsc-3.16.3/src/sys/objects/ftn-custom/zstart.c:280: undefined reference to `mpi_init_'
> /pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(baijfact.o): In function `MatSolve_SeqBAIJ_N':
> /pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1462: undefined reference to `zgemv_'
> /pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1475: undefined reference to `zgemv_'
> /pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1478: undefined reference to `zgemv_'
> /pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(baijfact.o): In function `MatSolve_SeqBAIJ_N_NaturalOrdering':
> /pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1407: undefined reference to `zgemv_'
> /pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1420: undefined reference to `zgemv_'
> /pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(baijfact.o):/pic/projects/gridpack/software/petsc-3.16.3/sr
> I suspect that the reason it worked for others and not for me is that they had viable blas and lapack libraries in their path and I don’t. Is there anything special you need to do to make sure that the build is pointed at the libraries that get created with the -download-f2cblaslapack option?
> Bruce Palmer
