[petsc-users] Configuring with CMake
Palmer, Bruce J
Bruce.Palmer at pnnl.gov
Tue Feb 22 10:03:01 CST 2022
We recently switched the CMake configuration on our GridPACK application to use the PkgConfig utility instead of Jeb Brown’s FindPETSc.cmake module. This seems to work on a number of platforms but it is failing to link on others. It appears that the build cannot find the LAPACK and BLAS libraries. The PETSc library I’m linking to (v3.16.3) was configured with -download-f2cblaslapack so it should have these libraries, but when I try and link one of the test applications in GridPACK I get the errors
/share/apps/gcc/6.1.0/bin/g++ -pthread -g -rdynamic CMakeFiles/greetings.dir/test/greetings.cpp.o -o greetings -Wl,-rpath,/qfs/projects/ops/rh6/openmpi/3.0.1/gcc/6.1.0/lib ../math/libgridpack_math.a libgridpack_parallel.a ../timer/libgridpack_timer.a ../environment/libgridpack_environment.a ../math/libgridpack_math.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_mpi.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_serialization.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_random.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_filesystem.a /pic/projects/gridpack/software/boost_1_65_0/lib/libboost_system.a /pic/projects/gridpack/software/ga-5.7/build_pr/lib/libga++.a /pic/projects/gridpack/software/ga-5.7/build_pr/lib/libga.a /pic/projects/gridpack/software/ga-5.7/build_pr/lib/libarmci.a -lrt /usr/lib64/librt.so /usr/lib64/libdl.so /qfs/projects/ops/rh6/openmpi/3.0.1/gcc/6.1.0/lib/libmpi.so ../timer/libgridpack_timer.a libgridpack_parallel.a ../configuration/libgridpack_configuration.a /pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a
/pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(zstart.o): In function `petscinitializef_':
/pic/projects/gridpack/software/petsc-3.16.3/src/sys/objects/ftn-custom/zstart.c:280: undefined reference to `mpi_init_'
/pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(baijfact.o): In function `MatSolve_SeqBAIJ_N':
/pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1462: undefined reference to `zgemv_'
/pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1475: undefined reference to `zgemv_'
/pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1478: undefined reference to `zgemv_'
/pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(baijfact.o): In function `MatSolve_SeqBAIJ_N_NaturalOrdering':
/pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1407: undefined reference to `zgemv_'
/pic/projects/gridpack/software/petsc-3.16.3/src/mat/impls/baij/seq/baijfact.c:1420: undefined reference to `zgemv_'
/pic/projects/gridpack/software/petsc-3.16.3/linux-openmpi-gnu-cxx-complex-opt/lib/libpetsc.a(baijfact.o):/pic/projects/gridpack/software/petsc-3.16.3/sr
I suspect that the reason it worked for others and not for me is that they had viable blas and lapack libraries in their path and I don’t. Is there anything special you need to do to make sure that the build is pointed at the libraries that get created with the -download-f2cblaslapack option?
Bruce Palmer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220222/5f5f6273/attachment.html>
