[petsc-users] Nodes Communication - Petsc Vec
Junchao Zhang junchao.zhang at gmail.com
Wed Feb 16 08:43:11 CST 2022
See Notes at
https://petsc.org/main/docs/manualpages/PetscSF/VecScatterCreate.html
Does it apply to your case?
--Junchao Zhang
On Wed, Feb 16, 2022 at 8:12 AM Medane TCHAKOROM <
medane.tchakorom at univ-fcomte.fr> wrote:
> Re:
> I forgot to mention that the nodes are in differents communicators. Does
> VecScatter functionnality still applies ?
> Thanks.
> On 16/02/2022 15:03, Matthew Knepley wrote:
> On Wed, Feb 16, 2022 at 8:55 AM Medane TCHAKOROM <
>> Hello,
>> I want to pass a Petsc Vec from one node to another one. Is there any
>> Petsc method for doing this
> You likely want the VecScatter functionality. There is a discussion of
> this in the manual:
> https://petsc.org/main/docs/manual/vec/?highlight=vecscatter#sec-unstruct
>   Thanks,
>     Matt
>> or should I use MPI_Irecv and MPI_Isend for non-blocking communication ?
>> When using MPI_Isend, can i send a Petsc Vec, or should I get the array
>> from it, and then send it ?
>> Thanks
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220216/b823c0ee/attachment.html>
