[petsc-users] Nodes Communication - Petsc Vec
Medane TCHAKOROM
medane.tchakorom at univ-fcomte.fr
Wed Feb 16 08:12:11 CST 2022
Re:
I forgot to mention that the nodes are in differents communicators. Does
VecScatter functionnality still applies ?
Thanks.
On 16/02/2022 15:03, Matthew Knepley wrote:
> On Wed, Feb 16, 2022 at 8:55 AM Medane TCHAKOROM
> <medane.tchakorom at univ-fcomte.fr> wrote:
> Hello,
> I want to pass a Petsc Vec from one node to another one. Is there any
> Petsc method for doing this
> You likely want the VecScatter functionality. There is a discussion of
> this in the manual:
> https://petsc.org/main/docs/manual/vec/?highlight=vecscatter#sec-unstruct
> Thanks,
> Matt
> or should I use MPI_Irecv and MPI_Isend for non-blocking
> communication ?
> When using MPI_Isend, can i send a Petsc Vec, or should I get the
> array
> from it, and then send it ?
> Thanks
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220216/5d9f927c/attachment.html>
