[petsc-users] 3.16.4 amd blis libflame linking problem
Fri Feb 4 10:39:36 CST 2022
On Fri, Feb 4, 2022 at 11:35 AM Anton Popov <popov at uni-mainz.de> wrote:
> Hi Satish,
> I just discovered that PETSc 3.16.4 fails to link against the latest AMD
> BLIS and LibFLAME libraries on a Linux box.
> You set a value for --with-blas-lib=<lib> and --with-lapack-lib=<lib>,
> but ['/opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a'] and
> ['/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a'] cannot be used
> My previous experience with 3.9.4 on the same system was fully
> successful. Looking in the configure logs (attached) reveals small
> difference in the linking compared to 3.9.4
> Could you please make a guess what went wrong?
Down in the log I see:
/usr/bin/ld: warning: libgfortran.so.5, needed by
/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so, not found (try using
-rpath or -rpath-link):
Did the gfortran library move or get upgraded?
     Matt
> Best regards,
> Anton
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220204/fbedad50/attachment.html>
