[petsc-users] 3.16.4 amd blis libflame linking problem
Anton Popov popov at uni-mainz.de
Fri Feb 4 10:35:10 CST 2022
Hi Satish,
I just discovered that PETSc 3.16.4 fails to link against the latest AMD
BLIS and LibFLAME libraries on a Linux box.
You set a value for --with-blas-lib=<lib> and --with-lapack-lib=<lib>,
but ['/opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a'] and
['/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a'] cannot be used
My previous experience with 3.9.4 on the same system was fully
successful. Looking in the configure logs (attached) reveals small
difference in the linking compared to 3.9.4
Could you please make a guess what went wrong?
Best regards,
Anton
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220204/aef658db/attachment-0001.bin>
