[petsc-users] cannot open source file "petsc.h"
Evstafyeva,Tamara te307 at cam.ac.uk
Thu Feb 3 13:25:30 CST 2022
Dear Satish,
Thank you for getting back!
I am attaching mu current GNUmakefile and the logs for it and the ex19.
Let me know if anything else is needed and thanks in advance,
Tamara
Date: Thursday, 3 February 2022, 18:53
To: Evstafyeva,Tamara <te307 at cam.ac.uk>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] cannot open source file "petsc.h"
Can you send your current makefile?
Also send compile log [including errors] when building with this makefile.
Also send us compile log from:
cd src/snes/tutorials
make ex19
Satish
On Thu, 3 Feb 2022, Evstafyeva,Tamara wrote:
> To whom it may concern,
> I am using a code that utilizes some of the PETSC capabilities. After configuring and installing PETSC on a cluster, I have set my environment variables $PETSC_DIR and $PETSC_ARCH. The code using PETSC compiles using GNUMakefile and so using instructions on the website and in Makefile.user I added the following lines to the make file:
> include ${PETSC_DIR}/lib/petsc/conf/variables
> include ${PETSC_DIR}/lib/petsc/conf/rules
> include ${PETSC_DIR}/lib/petsc/conf/test
> petsc.pc := $(PETSC_DIR)/$(PETSC_ARCH)/lib/pkgconfig/petsc.pc
> When compiling the code I get that the head files of PETSC are not recognized:
> catastrophic error: cannot open source file "petsc.h"
> This seems like a trivial problem, however I cannot seem to figure out what exactly went wrong. I’d expect this cannot be installation problem, and most likely the linking? I would really appreciate some direction on this problem.
> Thank you,
> Tamara
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220203/1a9776e5/attachment-0001.html>
Desc: GNUmakefile
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220203/1a9776e5/attachment-0003.obj>
Desc: log_ex19
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220203/1a9776e5/attachment-0004.obj>
Desc: log_main
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220203/1a9776e5/attachment-0005.obj>
