[petsc-users] cannot open source file "petsc.h"
Jed Brown jed at jedbrown.org
Thu Feb 3 12:51:31 CST 2022
Hmm, usually we don't use BOTH the makefile includes and pkgconfig (as in Makefile.user). You can use either. If you share the whole file and the command line that executes, I think it'll be easy enough to fix.
"Evstafyeva,Tamara" <te307 at cam.ac.uk> writes:
> To whom it may concern,
> I am using a code that utilizes some of the PETSC capabilities. After configuring and installing PETSC on a cluster, I have set my environment variables $PETSC_DIR and $PETSC_ARCH. The code using PETSC compiles using GNUMakefile and so using instructions on the website and in Makefile.user I added the following lines to the make file:
> include ${PETSC_DIR}/lib/petsc/conf/variables
> include ${PETSC_DIR}/lib/petsc/conf/rules
> include ${PETSC_DIR}/lib/petsc/conf/test
> petsc.pc := $(PETSC_DIR)/$(PETSC_ARCH)/lib/pkgconfig/petsc.pc
> When compiling the code I get that the head files of PETSC are not recognized:
> catastrophic error: cannot open source file "petsc.h"
> This seems like a trivial problem, however I cannot seem to figure out what exactly went wrong. I’d expect this cannot be installation problem, and most likely the linking? I would really appreciate some direction on this problem.
> Thank you,
> Tamara
