[petsc-users] cannot open source file "petsc.h"
Evstafyeva,Tamara te307 at cam.ac.uk
Thu Feb 3 11:22:16 CST 2022
To whom it may concern,
I am using a code that utilizes some of the PETSC capabilities. After configuring and installing PETSC on a cluster, I have set my environment variables $PETSC_DIR and $PETSC_ARCH. The code using PETSC compiles using GNUMakefile and so using instructions on the website and in Makefile.user I added the following lines to the make file:
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
include ${PETSC_DIR}/lib/petsc/conf/test
petsc.pc := $(PETSC_DIR)/$(PETSC_ARCH)/lib/pkgconfig/petsc.pc
When compiling the code I get that the head files of PETSC are not recognized:
catastrophic error: cannot open source file "petsc.h"
This seems like a trivial problem, however I cannot seem to figure out what exactly went wrong. I’d expect this cannot be installation problem, and most likely the linking? I would really appreciate some direction on this problem.
Thank you,
Tamara
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220203/d25fe62e/attachment.html>
