[petsc-users] Using Finite Difference Jacobian with TS
Wed Feb 2 17:15:57 CST 2022
On Wed, Feb 2, 2022 at 6:08 PM Jorti, Zakariae via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello,
> I am using a TS to solve a differential algebraic equation (DAE).
> I do not provide the Jacobian matrix but instead set the TS to use a
> finite difference jacobian with coloring.
> For debugging, I only solve this DAE on one time step.
> Is there a way to output this finite difference jacobian in a matlab
> format (.m file)?
> I have already tried this flag : -mat_view ascii:ColFDJac.m:ascii_matlab ,
> but when I use it the test takes too long. My guess is that this flag  is
> trying to save all the matrices involved in the computations. I am  only
> interested in the jacobian though.
I tend to use -ksp_mat_view ascii:ColFDJac.m:ascii_matlab since that only
outputs the KSP system matrix.
    Matt
> Thank you.
> Best,
> Zakariae
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220202/a2bcedc8/attachment.html>
