[petsc-users] Question-Memory of matsetvalue
Jed Brown
jed at jedbrown.org
Fri Dec 30 08:30:28 CST 2022
This is what I'd expect to observe if you didn't preallocate correctly for the second matrix, which has more nonzeros per row.
https://petsc.org/release/docs/manual/mat/#sec-matsparse
김성익 <ksi2443 at gmail.com> writes:
> Hello,
> I have a question about memory of matsetvalue.
> When I assembly the local matrix to global matrix, I’m just using
> matsetvalue.
> Because the connectivity is so complex I can’t use matsetvalues.
> I asked this question because I was curious about how ram memory is
> allocated differently for the two simtuations below.
> First situation.
> The local matrix size is 24 by 24. And the number of local matrix is
> 125,000.
> When assembly procedure by using matsetvalue, memory allocation does not
> increase.
> So I just put Matassemblybegin and matassemblyend after all matsetvalue.
> Second situation.
> The local matrix size is 60 by 60. And the number of local matrix is 27,000.
> increase.
> So I just put Matassemblybegin and matassemblyend after each local matrix
> assembly.
> This did not increase the memory further..
> Why this situation is happen?
> And is there any way to prevent the memory allocation from increasing?
> Thanks,
> Hyung Kim
