[petsc-users] gamg out of memory with gpu
Matthew Knepley
knepley at gmail.com
Mon Dec 26 08:39:10 CST 2022
On Mon, Dec 26, 2022 at 4:41 AM Edoardo Centofanti <
edoardo.centofanti01 at universitadipavia.it> wrote:
> Hi PETSc Users,
> I am experimenting some issues with the GAMG precondtioner when used with
> GPU.
> In particular, it seems to go out of memory very easily (around 5000
> dofs are enough to make it throw the "[0]PETSC ERROR: cuda error 2
> (cudaErrorMemoryAllocation) : out of memory" error).
> I have these issues both with single and multiple GPUs (on the same or on
> different nodes). The exact same problems work like a charm with HYPRE
> BoomerAMG on GPUs.
> With both preconditioners I exploit the device acceleration by giving the
> usual command line options "-dm_vec_type cuda" and "-dm_mat_type
> aijcusparse" (I am working with structured meshes). My PETSc version is
> 3.17.
> Is this a known issue of the GAMG preconditioner?
No. Can you get it to do this with a PETSc example? Say SNES ex5?
Matt
> Thank you in advance,
> Edoardo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221226/4823dd39/attachment.html>
