[petsc-users] Error while running an example
Guilherme Lima grezende.oliv at gmail.com
Wed Dec 21 11:11:56 CST 2022
Hello
So, this error occurred while running example 50 on
petsc/src/ksp/ksp/tutorials
The machine also have a MPI installed, so in order to run the ex50 I did:
/home/slave12/projects/petsc/arch-linux-c-debug/bin/mpiexec -n 4 ./ex50
 -da_grid_x 120 -da_grid_y 120 -pc_type lu -pc_factor_mat_solver_type
superlu_dist -ksp_monitor -ksp_view
Expecting that the problem was solved, but instead it showed an Error
message
Configure.log, make.log and error attached.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221221/0e8bcef5/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221221/0e8bcef5/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221221/0e8bcef5/attachment-0003.bin>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221221/0e8bcef5/attachment-0001.jpeg>
