[petsc-users] Installation issues
Mon Dec 19 14:31:30 CST 2022
This occurs if one uses an incompatible mpiexec [to the mpi that PETSc was installed with.
I see you've installed using -download-mpich
So the compatible mpiexec here is
MPIEXEC = /home/slave12/projects/petsc/arch-linux-c-debug/bin/mpiexec
So try:
/home/slave12/projects/petsc/arch-linux-c-debug/bin/mpiexec -n 4 ./ex50
Satish
On Mon, 19 Dec 2022, Guilherme Lima wrote:
> Hello,
> I'm having an issue with my PETSc installation. It started with an
> unexpected output on src/ksp/ksp/tutorial ex50, then tried doing the
> configuring early steps again and here I am.
> It can't execute more than 1 MPI process, also at the example that I
> mentioned before, using "mpiexec -n 4 ... " it appeared to have executed
> the same interaction 4 times, instead of 1 time with 4 processors.
> Hope I've been clear about what is the problem.
