[petsc-users] ??????  out of date warning when petscmpiexec.
    Satish Balay
    balay at mcs.anl.gov
    Thu Dec 15 12:30:19 CST 2022
Ok - so for whatever reason your petsc build  were indeed out of date - and "make -f gmakefile libs" updated the library.
Wrt out-of-date executable message - I think its due to the old formatted makefile.
You can do the following:
- edit  p4pdes/c/ch1/makefile
- remove the line: '	${RM} e.o'
- run 'make e'
Now retry:
petscmpiexec -n 1 ./e
Satish
On Fri, 16 Dec 2022, Syvshc wrote:
> I got lots of build information,
> and after "make -f gmakefile libs", the out of date warning of petscmpiexec was gone.
> ?7?9 petscmpiexec -n 1 ./e
> Warning: ************** The executable ./e is out of date
> e is about 1.000000000000000
> rank 0 did 0 flops
> BTW, if I want to know something of the "executable out of date" question,
> should I send a new mail or I can just ask under these mails?
> Thanks for your help sincerely.
> Syvshc
> ??????:        "petsc-users"        <balay at mcs.anl.gov>;
> ????????: 2022??12??16??(??????) ????2:11
> ??????: "Syvshc"<syvshc at foxmail.com>;
> ????: "petsc-users"<petsc-users at mcs.anl.gov>;
> ????: Re: [petsc-users] out of date warning when petscmpiexec.
> > make -q -f gmakefile libs
> > echo $?
> > 1
> So "make" does think the library is out-of-date. If up-to-date - you should see a '0' - not '1'. One more try:
> what do you get for:
> cd $PETSC_DIR
> make -f gmakefile libs  # i.e without -q
> Satish
> > I still get this warning, I found that "make -q" command won't get any respond.
> > Here is the whole output:
> > ?7?9 cd $PETSC_DIR
> > echo $?
> > cd ~/git/p4pdes/c/ch1
> > make -q e
> > echo $?
> > make clean
> > make e
> > make -q e
> > echo $?
> > 1
> > 1
> > Warning: ************** The PETSc libraries are out of date
> > rank 0 did 0 flops
> > mpicc -o e.o -c -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0 -pedantic -std=c99 -I/home/syvshclily/git/petsc/petsc-latest/include -I/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/include    `pwd`/e.c
> > mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0 -pedantic -std=c99 -o e e.o  -Wl,-rpath,/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -L/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -Wl,-rpath,/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -L/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0 -L/usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0 -lpetsc -lsuperlu_dist -llapack -lblas -lm -lX11 -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
> > /usr/sbin/rm -f e.o
> > 1
> > rank 0 did 0 flops
> > Thanks for your reply.
> > Syvshc
> > ------------------ Original ------------------
> > From:        "petsc-users"                                         &nbs
 p;
> > Date: Fri, Dec 16, 2022 01:40 AM
> > To: "Syvshc"<syvshc at foxmail.com>;
> > Cc: "petsc-users"<petsc-users at mcs.anl.gov>;
> > Subject: Re: [petsc-users] out of date warning when petscmpiexec.
> > That's strange. Do you still get this warning from petscmpiexec?
> > Can you run these commands - and copy/paste the *complete* session from your terminal [for these commands and their output on terminal] ?
> > cd $PETSC_DIR
> > echo $?
> > cd bueler/p4pdes
> > make -q e
> > echo $?
> > make clean
> > make e
> > make -q e
> > echo $?
> > Alternatively you can just use mpiexec [ i.e not use petscmpiexec - its just a convenience wrapper over using correct mpiexec/valgrind].
> > Satish
> > > I run this command in the root dir of my petsc, and didn't get any response.
> > > ------------------&nbsp;Original&nbsp;------------------
> > > From:
 ;&nb
 sp;                      "petsc-users"        &a
 mp;nbsp;
        <balay at mcs.anl.gov&gt;;
> > > Date:&nbsp;Thu, Dec 15, 2022 10:19 PM
> > > To:&nbsp;"Syvshc"<syvshc at foxmail.com&gt;;
> > > Cc:&nbsp;"petsc-users"<petsc-users at mcs.anl.gov&gt;;
> > > Subject:&nbsp;Re: [petsc-users] out of date warning when petscmpiexec.
> > > What do you get - if you invoke the following command in petsc source dir?
> > > [this is the test petscmpiexec is using to check if "libraries are out of date"]
> > > Satish
> > > On Thu, 15 Dec 2022, Syvshc wrote:
> > > &gt; I'm a beginner with petsc, and I'm reading&amp;nbsp;PETSc for Partial Differential Equations.&amp;nbsp;
> > > &gt;
> > > &gt; There is the newest release version (3.18.2) of PETSc's gitlab repo on my device, and openmpi in my system (/usr/sbin/).&amp;nbsp;
> > > &gt;
> > > &gt;
> > > &gt; Here is the repo and what I tried to compiling.&amp;nbsp;p4pdes/e.c at master ?? bueler/p4pdes (github.com)
> > > &gt;
> > > &gt;
> > > &gt; After "make e", I got an excutable file "e". "./e" or "mpiexec -n 4 ./e" can perfectly run.&amp;nbsp;
> > > &gt;
> > > &gt;
> > > &gt; However when I use "petscmpiexec -n 4 ./e", I got some warnings:
> > > &gt;
> > > &gt;
> > > &gt; Warning: ************** The PETSc libraries are out of date
> > > &gt; Warning: ************** The executable ./e is out of date
> > > &gt;
> > > &gt;
> > > &gt; What should I do to fix the warning?
> > > &gt;
> > > &gt;
> > > &gt; Also this is the first time that I send to a mail-list, if there are some mistakes I made, please tell me.&amp;nbsp;
> > > &gt;
> > > &gt;
> > > &gt; Kind regards,
> > > &gt;
> > > &gt;
> > > &gt; Syvshc
