[petsc-users] out of date warning when petscmpiexec.
Satish Balay
balay at mcs.anl.gov
Thu Dec 15 12:11:19 CST 2022
> make -q -f gmakefile libs
> echo $?
> 1
So "make" does think the library is out-of-date. If up-to-date - you should see a '0' - not '1'. One more try:
what do you get for:
cd $PETSC_DIR
make -f gmakefile libs # i.e without -q
Satish
On Fri, 16 Dec 2022, Syvshc wrote:
> I still get this warning, I found that "make -q" command won't get any respond.
> Here is the whole output:
> ?7?9 cd $PETSC_DIR
> echo $?
> cd ~/git/p4pdes/c/ch1
> make -q e
> echo $?
> petscmpiexec -n 1 ./e
> make clean
> make e
> make -q e
> echo $?
> 1
> 1
> Warning: ************** The PETSc libraries are out of date
> Warning: ************** The executable ./e is out of date
> e is about 1.000000000000000
> rank 0 did 0 flops
> mpicc -o e.o -c -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0 -pedantic -std=c99 -I/home/syvshclily/git/petsc/petsc-latest/include -I/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/include `pwd`/e.c
> mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector -fvisibility=hidden -g3 -O0 -pedantic -std=c99 -o e e.o -Wl,-rpath,/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -L/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -Wl,-rpath,/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -L/home/syvshclily/git/petsc/petsc-latest/arch-linux-c-debug/lib -Wl,-rpath,/usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0 -L/usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0 -lpetsc -lsuperlu_dist -llapack -lblas -lm -lX11 -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl
> /usr/sbin/rm -f e.o
> 1
> rank 0 did 0 flops
> Thanks for your reply.
> Syvshc
> ------------------ Original ------------------
> From: "petsc-users" <balay at mcs.anl.gov>;
> Date: Fri, Dec 16, 2022 01:40 AM
> To: "Syvshc"<syvshc at foxmail.com>;
> Cc: "petsc-users"<petsc-users at mcs.anl.gov>;
> Subject: Re: [petsc-users] out of date warning when petscmpiexec.
> That's strange. Do you still get this warning from petscmpiexec?
> Can you run these commands - and copy/paste the *complete* session from your terminal [for these commands and their output on terminal] ?
> cd $PETSC_DIR
> echo $?
> cd bueler/p4pdes
> make -q e
> echo $?
> make clean
> make e
> make -q e
> echo $?
> Alternatively you can just use mpiexec [ i.e not use petscmpiexec - its just a convenience wrapper over using correct mpiexec/valgrind].
> Satish
> > I run this command in the root dir of my petsc, and didn't get any response.
> > From: "petsc-users" &nbs
p;
> > Date: Thu, Dec 15, 2022 10:19 PM
> > What do you get - if you invoke the following command in petsc source dir?
> > [this is the test petscmpiexec is using to check if "libraries are out of date"]
> > Satish
> > On Thu, 15 Dec 2022, Syvshc wrote:
> > > I'm a beginner with petsc, and I'm reading&nbsp;PETSc for Partial Differential Equations.&nbsp;
> > > There is the newest release version (3.18.2) of PETSc's gitlab repo on my device, and openmpi in my system (/usr/sbin/).&nbsp;
> > > Here is the repo and what I tried to compiling.&nbsp;p4pdes/e.c at master ?? bueler/p4pdes (github.com)
> > > After "make e", I got an excutable file "e". "./e" or "mpiexec -n 4 ./e" can perfectly run.&nbsp;
> > > However when I use "petscmpiexec -n 4 ./e", I got some warnings:
> > > What should I do to fix the warning?
> > > Also this is the first time that I send to a mail-list, if there are some mistakes I made, please tell me.&nbsp;
> > > Kind regards,
> > > Syvshc
