[petsc-users] out of date warning when petscmpiexec.
Syvshc
syvshc at foxmail.com
Thu Dec 15 11:29:47 CST 2022
I run this command in the root dir of my petsc, and didn't get any response.
------------------ Original ------------------
Date: Thu, Dec 15, 2022 10:19 PM
To: "Syvshc"<syvshc at foxmail.com>;
Cc: "petsc-users"<petsc-users at mcs.anl.gov>;
Subject: Re: [petsc-users] out of date warning when petscmpiexec.
What do you get - if you invoke the following command in petsc source dir?
make -q -f gmakefile libs
[this is the test petscmpiexec is using to check if "libraries are out of date"]
Satish
On Thu, 15 Dec 2022, Syvshc wrote:
> I'm a beginner with petsc, and I'm reading PETSc for Partial Differential Equations.
> There is the newest release version (3.18.2) of PETSc's gitlab repo on my device, and openmpi in my system (/usr/sbin/).
> Here is the repo and what I tried to compiling. p4pdes/e.c at master · bueler/p4pdes (github.com)
> After "make e", I got an excutable file "e". "./e" or "mpiexec -n 4 ./e" can perfectly run.
> However when I use "petscmpiexec -n 4 ./e", I got some warnings:
> Warning: ************** The PETSc libraries are out of date
> Warning: ************** The executable ./e is out of date
> What should I do to fix the warning?
> Also this is the first time that I send to a mail-list, if there are some mistakes I made, please tell me.
> Kind regards,
> Syvshc
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221216/7d5a0377/attachment.html>
