[petsc-users] GAMG and linearized elasticity
    Mark Adams
    mfadams at lbl.gov
    Wed Dec 14 13:12:09 CST 2022
On Wed, Dec 14, 2022 at 1:11 PM Blaise Bourdin <bourdin at mcmaster.ca> wrote:
> Hi Mark,
> On Dec 14, 2022, at 11:07 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Dec 14, 2022 at 9:38 AM Blaise Bourdin <bourdin at mcmaster.ca>
> wrote:
>> Hi Jed,
>> Thanks for pointing us in the right direction.
>> We were using MatNullSpaceCreateRigidBody which does not know anything
>> about the discretization, hence our issues with quadratic elements.
>> DMPlexCreate RigidBody does not work out of the box for us since we do not
>> use PetscFE at the moment, but we can easily build the near null space by
>> hand.
> Oh, MatNullSpaceCreateRigidBody should work because it takes the
> coordinates. You just need to get the coordinates for all the
> points/vertices.
> Or you can build it by hand.
> I don't know of DMPlexCreate RigidBody does the right thing. This would
> take a little code and I'm not sure if (Matt) did this (kinda doubt it). It
> should error out if not, but you don't use it anyway.
> Did you call MatNullSpaceCreateRigidBody with a vector of coordinates that
> only has the corner points? (In that case it should have through an error)
> Yes. I need to figure out why it did not throw an error.
I see that MatNullSpaceCreateRigidBody is not a Mat method! This is really
just a utility method that creates the RBMs for each "node" and does not
relate to a matrix to make sure they match.
Now you must call MatSetNearNullSpace(A, matnull);
I see the problem now. MatSetNearNullSpace simply attached matnull to A,
and then GAMG grabs that and copies the data in.
GAMG does not check the sizes. So the null space that GAMG used was garbage
and it read past the end of the provided null space vectors.
I'll add a check.
>> FWIW, removing the wrong null space brought GAMG iteration number to
>> something more reasonable
> Good. I'm not sure what happened, but MatNullSpaceCreateRigidBody should
> work unless you have a non-standard element and you can always test it by
> call MatMult on the RBMs and verify that its a null space, away from the
> BCs.
> Will do.
> All in all, the easiest for me to to rebuild the null space. This way, I
> am absolutely certain that it will works, regardless of my FE space.
> Blaise
>> Thanks a million,
>> Blaise
>> On Dec 13, 2022, at 10:37 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Do you have slip/symmetry boundary conditions, where some components are
>> constrained? In that case, there is no uniform block size and I think
>> you'll need DMPlexCreateRigidBody() and MatSetNearNullSpace().
>> The PCSetCoordinates() code won't work for non-constant block size.
>> -pc_type gamg should work okay out of the box for elasticity. For hypre,
>> I've had good luck with this options suite, which also runs on GPU.
>> -pc_type hypre -pc_hypre_boomeramg_coarsen_type pmis
>> -pc_hypre_boomeramg_interp_type ext+i -pc_hypre_boomeramg_no_CF
>> -pc_hypre_boomeramg_P_max 6 -pc_hypre_boomeramg_relax_type_down Chebyshev
>> -pc_hypre_boomeramg_relax_type_up Chebyshev
>> -pc_hypre_boomeramg_strong_threshold 0.5
>> Blaise Bourdin <bourdin at mcmaster.ca> writes:
>> Hi,
>> I am getting close to finish porting a code from petsc 3.3 / sieve to
>> main / dmplex, but am
>> now encountering difficulties
>> I am reasonably sure that the Jacobian and residual are correct. The
>> codes handle boundary
>> conditions differently (MatZeroRowCols vs dmplex constraints) so it is
>> not trivial to compare
>> them. Running with snes_type ksponly pc_type Jacobi or hyper gives me the
>> same results in
>> roughly the same number of iterations.
>> In my old code, gamg would work out of the box. When using petsc-main,
>> -pc_type gamg -
>> pc_gamg_type agg works for _some_ problems using P1-Lagrange elements,
>> but never for
>> P2-Lagrange. The typical error message is in gamg_agg.txt
>> When using -pc_type classical, a problem where the KSP would converge in
>> 47 iteration in
>> 3.3 now takes 1400.  ksp_view_3.3.txt and ksp_view_main.txt show the
>> output of -ksp_view
>> for both versions. I don’t notice anything obvious.
>> Strangely, removing the call to PCSetCoordinates does not have any impact
>> on the
>> convergence.
>> I am sure that I am missing something, or not passing the right options.
>> What’s a good
>> starting point for 3D elasticity?
>> Regards,
>> Blaise
>> Canada Research Chair in Mathematical and Computational Aspects of Solid
>> Mechanics
>> (Tier 1)
>> Professor, Department of Mathematics & Statistics
>> Hamilton Hall room 409A, McMaster University
>> 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
>> https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> [0]PETSC ERROR: Computed maximum singular value as zero
>> [0]PETSC ERROR: WARNING! There are option(s) set that were not used!
>> Could be the program crashed before they were used or a spelling mistake,
>> etc!
>> [0]PETSC ERROR: Option left: name:-displacement_ksp_converged_reason
>> value: ascii source: file
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.18.2-341-g16200351da0
>>  GIT Date: 2022-12-12 23:42:20 +0000
>> [0]PETSC ERROR:
>> /home/bourdinb/Development/mef90/mef90-dmplex/bbserv-gcc11.2.1-mvapich2-2.3.7-O/bin/ThermoElasticity
>> on a bbserv-gcc11.2.1-mvapich2-2.3.7-O named bb01 by bourdinb Tue Dec 13
>> 17:02:19 2022
>> [0]PETSC ERROR: Configure options --CFLAGS=-Wunused
>> --FFLAGS="-ffree-line-length-none -fallow-argument-mismatch -Wunused"
>> --COPTFLAGS="-O2 -march=znver2" --CXXOPTFLAGS="-O2 -march=znver2"
>> --FOPTFLAGS="-O2 -march=znver2" --download-chaco=1 --download-exodusii=1
>> --download-fblaslapack=1 --download-hdf5=1 --download-hypre=1
>> --download-metis=1 --download-ml=1 --download-mumps=1 --download-netcdf=1
>> --download-p4est=1 --download-parmetis=1 --download-pnetcdf=1
>> --download-scalapack=1 --download-sowing=1
>> --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc
>> --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++
>> --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp
>> --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp
>> --download-superlu=1 --download-triangle=1 --download-yaml=1
>> --download-zlib=1 --with-debugging=0
>> --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-pic
>> --with-shared-libraries=1 --with-mpiexec=srun --with-x11=0
>> [0]PETSC ERROR: #1 PCGAMGOptProlongator_AGG() at
>> /1/HPC/petsc/main/src/ksp/pc/impls/gamg/agg.c:779
>> [0]PETSC ERROR: #2 PCSetUp_GAMG() at
>> /1/HPC/petsc/main/src/ksp/pc/impls/gamg/gamg.c:639
>> [0]PETSC ERROR: #3 PCSetUp() at
>> /1/HPC/petsc/main/src/ksp/pc/interface/precon.c:994
>> [0]PETSC ERROR: #4 KSPSetUp() at
>> /1/HPC/petsc/main/src/ksp/ksp/interface/itfunc.c:405
>> [0]PETSC ERROR: #5 KSPSolve_Private() at
>> /1/HPC/petsc/main/src/ksp/ksp/interface/itfunc.c:824
>> [0]PETSC ERROR: #6 KSPSolve() at
>> /1/HPC/petsc/main/src/ksp/ksp/interface/itfunc.c:1070
>> [0]PETSC ERROR: #7 SNESSolve_KSPONLY() at
>> /1/HPC/petsc/main/src/snes/impls/ksponly/ksponly.c:48
>> [0]PETSC ERROR: #8 SNESSolve() at
>> /1/HPC/petsc/main/src/snes/interface/snes.c:4693
>> [0]PETSC ERROR: #9
>> /home/bourdinb/Development/mef90/mef90-dmplex/ThermoElasticity/ThermoElasticity.F90:228
>>  Linear solve converged due to CONVERGED_RTOL iterations 46
>> KSP Object:(Disp_) 32 MPI processes
>>  type: cg
>>  maximum iterations=10000
>>  tolerances:  relative=1e-05, absolute=1e-08, divergence=1e+10
>>  left preconditioning
>>  using nonzero initial guess
>>  using PRECONDITIONED norm type for convergence test
>> PC Object:(Disp_) 32 MPI processes
>>  type: gamg
>>    MG: type is MULTIPLICATIVE, levels=4 cycles=v
>>      Cycles per PCApply=1
>>      Using Galerkin computed coarse grid matrices
>>  Coarse grid solver -- level -------------------------------
>>    KSP Object:    (Disp_mg_coarse_)     32 MPI processes
>>      type: gmres
>>        GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
>> Orthogonalization with no iterative refinement
>>        GMRES: happy breakdown tolerance 1e-30
>>      maximum iterations=1, initial guess is zero
>>      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>>      using NONE norm type for convergence test
>>    PC Object:    (Disp_mg_coarse_)     32 MPI processes
>>      type: bjacobi
>>        block Jacobi: number of blocks = 32
>>        Local solve info for each block is in the following KSP and PC
>> objects:
>>      [0] number of local blocks = 1, first local block number = 0
>>        [0] local block number 0
>>        KSP Object:        (Disp_mg_coarse_sub_)         1 MPI processes
>>          type: preonly
>>          maximum iterations=10000, initial guess is zero
>>        PC Object:        (Disp_mg_coarse_sub_)         1 MPI processes
>>          type: lu
>>          type: preonly
>>            LU: out-of-place factorization
>>            tolerance for zero pivot 2.22045e-14
>>            matrix ordering: nd
>>            factor fill ratio given 5, needed 1.06061
>>              Factored matrix follows:
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>            factor fill ratio given 5, needed 0
>>                Matrix Object:                 1 MPI processes
>>          type: preonly
>>          type: lu
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>                  rows=0, cols=0, bs=6
>>                  package used to perform factorization: petsc
>>                  total: nonzeros=1, allocated nonzeros=1
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>                  total number of mallocs used during MatSetValues calls =0
>>                    not using I-node routines
>>          linear system matrix = precond matrix:
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>            total: nonzeros=0, allocated nonzeros=0
>>                  type: seqaij
>>                  rows=54, cols=54, bs=6
>>                  total: nonzeros=1260, allocated nonzeros=1260
>>                    using I-node routines: found 16 nodes, limit used is 5
>>            type: seqaij
>>            total: nonzeros=1188, allocated nonzeros=1188
>>              using I-node routines: found 17 nodes, limit used is 5
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>            type: seqaij
>>            type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: preonly
>>          type: lu
>>          type: preonly
>>          type: lu
>>          type: lu
>>            matrix ordering: nd
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>            matrix ordering: nd
>>                  type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>            matrix ordering: nd
>>                  type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>      [1] number of local blocks = 1, first local block number = 1
>>        [1] local block number 0
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>                  type: seqaij
>>            type: seqaij
>>          type: preonly
>>          type: lu
>>            matrix ordering: nd
>>                  type: seqaij
>>            type: seqaij
>>      [2] number of local blocks = 1, first local block number = 2
>>        [2] local block number 0
>>      [3] number of local blocks = 1, first local block number = 3
>>        [3] local block number 0
>>      [4] number of local blocks = 1, first local block number = 4
>>        [4] local block number 0
>>      [5] number of local blocks = 1, first local block number = 5
>>        [5] local block number 0
>>      [6] number of local blocks = 1, first local block number = 6
>>        [6] local block number 0
>>      [7] number of local blocks = 1, first local block number = 7
>>        [7] local block number 0
>>      [8] number of local blocks = 1, first local block number = 8
>>        [8] local block number 0
>>      [9] number of local blocks = 1, first local block number = 9
>>        [9] local block number 0
>>      [10] number of local blocks = 1, first local block number = 10
>>        [10] local block number 0
>>      [11] number of local blocks = 1, first local block number = 11
>>        [11] local block number 0
>>      [12] number of local blocks = 1, first local block number = 12
>>        [12] local block number 0
>>      [13] number of local blocks = 1, first local block number = 13
>>        [13] local block number 0
>>      [14] number of local blocks = 1, first local block number = 14
>>        [14] local block number 0
>>      [15] number of local blocks = 1, first local block number = 15
>>        [15] local block number 0
>>      [16] number of local blocks = 1, first local block number = 16
>>        [16] local block number 0
>>      [17] number of local blocks = 1, first local block number = 17
>>        [17] local block number 0
>>      [18] number of local blocks = 1, first local block number = 18
>>        [18] local block number 0
>>      [19] number of local blocks = 1, first local block number = 19
>>        [19] local block number 0
>>      [20] number of local blocks = 1, first local block number = 20
>>        [20] local block number 0
>>      [21] number of local blocks = 1, first local block number = 21
>>        [21] local block number 0
>>      [22] number of local blocks = 1, first local block number = 22
>>        [22] local block number 0
>>      [23] number of local blocks = 1, first local block number = 23
>>        [23] local block number 0
>>      [24] number of local blocks = 1, first local block number = 24
>>        [24] local block number 0
>>      [25] number of local blocks = 1, first local block number = 25
>>        [25] local block number 0
>>      [26] number of local blocks = 1, first local block number = 26
>>        [26] local block number 0
>>      [27] number of local blocks = 1, first local block number = 27
>>        [27] local block number 0
>>      [28] number of local blocks = 1, first local block number = 28
>>        [28] local block number 0
>>      [29] number of local blocks = 1, first local block number = 29
>>        [29] local block number 0
>>      [30] number of local blocks = 1, first local block number = 30
>>        [30] local block number 0
>>      [31] number of local blocks = 1, first local block number = 31
>>        [31] local block number 0
>>      Matrix Object:       32 MPI processes
>>        type: mpiaij
>>          using I-node (on process 0) routines: found 17 nodes, limit used
>> is 5
>>  Down solver (pre-smoother) on level 1 -------------------------------
>>    KSP Object:    (Disp_mg_levels_1_)     32 MPI processes
>>      type: chebyshev
>>        Chebyshev: eigenvalue estimates:  min = 0.101023, max = 2.13327
>>      maximum iterations=2
>>    PC Object:    (Disp_mg_levels_1_)     32 MPI processes
>>      type: jacobi
>>        type: mpiaij
>>        rows=1086, cols=1086, bs=6
>>        total: nonzeros=67356, allocated nonzeros=67356
>>          using I-node (on process 0) routines: found 362 nodes, limit
>> used is 5
>>  Up solver (post-smoother) same as down solver (pre-smoother)
>>  Down solver (pre-smoother) on level 2 -------------------------------
>>    KSP Object:    (Disp_mg_levels_2_)     32 MPI processes
>>      type: chebyshev
>>        Chebyshev: eigenvalue estimates:  min = 0.0996526, max = 2.29388
>>    PC Object:    (Disp_mg_levels_2_)     32 MPI processes
>>      type: jacobi
>>        type: mpiaij
>>        rows=23808, cols=23808, bs=6
>>        total: nonzeros=1976256, allocated nonzeros=1976256
>>          using I-node (on process 0) routines: found 7936 nodes, limit
>> used is 5
>>  Down solver (pre-smoother) on level 3 -------------------------------
>>    KSP Object:    (Disp_mg_levels_3_)     32 MPI processes
>>      type: chebyshev
>>        Chebyshev: eigenvalue estimates:  min = 0.165968, max = 2.13065
>>    PC Object:    (Disp_mg_levels_3_)     32 MPI processes
>>      type: jacobi
>>      Matrix Object:      (Disp_)       32 MPI processes
>>        type: mpiaij
>>        rows=291087, cols=291087
>>        total: nonzeros=12323691, allocated nonzeros=12336696
>>          using I-node (on process 0) routines: found 3419 nodes, limit
>> used is 5
>>    type: mpiaij
>>      using I-node (on process 0) routines: found 3419 nodes, limit used
>> is 5
>> SNESConvergedReason returned            5
>> KSP Object: (Displacement_) 32 MPI processes
>>  type: cg
>>  maximum iterations=10000, nonzero initial guess
>> PC Object: (Displacement_) 32 MPI processes
>>  type: gamg
>>      Using externally compute Galerkin coarse grid matrices
>>      GAMG specific options
>>        Threshold for dropping small values in graph on each level =   -1.
>>   -1.   -1.   -1.
>>        Threshold scaling factor for each level not specified = 1.
>>        Complexity:    grid = 1.02128    operator = 1.05534
>>  Coarse grid solver -- level 0 -------------------------------
>>    KSP Object: (Displacement_mg_coarse_) 32 MPI processes
>>      type: preonly
>>      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>    PC Object: (Displacement_mg_coarse_) 32 MPI processes
>>      type: bjacobi
>>        Local solver information for first block is in the following KSP
>> and PC objects on rank 0:
>>        Use -Displacement_mg_coarse_ksp_view ::ascii_info_detail to
>> display information for all blocks
>>      KSP Object: (Displacement_mg_coarse_sub_) 1 MPI process
>>        type: preonly
>>      PC Object: (Displacement_mg_coarse_sub_) 1 MPI process
>>        type: lu
>>          using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>          matrix ordering: nd
>>          factor fill ratio given 5., needed 1.08081
>>              Mat Object: (Displacement_mg_coarse_sub_) 1 MPI process
>>                type: seqaij
>>                rows=20, cols=20
>>                total: nonzeros=214, allocated nonzeros=214
>>                  using I-node routines: found 8 nodes, limit used is 5
>>          type: seqaij
>>          rows=20, cols=20
>>          total: nonzeros=198, allocated nonzeros=198
>>          total number of mallocs used during MatSetValues calls=0
>>            using I-node routines: found 13 nodes, limit used is 5
>>      Mat Object: 32 MPI processes
>>        type: mpiaij
>>        rows=20, cols=20
>>          using I-node (on process 0) routines: found 13 nodes, limit used
>> is 5
>>    KSP Object: (Displacement_mg_levels_1_) 32 MPI processes
>>      type: chebyshev
>>        eigenvalue targets used: min 0.81922, max 9.01143
>>        eigenvalues estimated via gmres: min 0.186278, max 8.1922
>>        eigenvalues estimated using gmres with transform: [0. 0.1; 0. 1.1]
>>        KSP Object: (Displacement_mg_levels_1_esteig_) 32 MPI processes
>>          type: gmres
>>          maximum iterations=10, initial guess is zero
>>          tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
>>        estimating eigenvalues using noisy right hand side
>>      maximum iterations=2, nonzero initial guess
>>    PC Object: (Displacement_mg_levels_1_) 32 MPI processes
>>      type: jacobi
>>        type DIAGONAL
>>        type: mpiaij
>>        rows=799, cols=799
>>        total: nonzeros=83159, allocated nonzeros=83159
>>          using I-node (on process 0) routines: found 23 nodes, limit used
>> is 5
>>    KSP Object: (Displacement_mg_levels_2_) 32 MPI processes
>>      type: chebyshev
>>        eigenvalue targets used: min 1.16291, max 12.792
>>        eigenvalues estimated via gmres: min 0.27961, max 11.6291
>>        KSP Object: (Displacement_mg_levels_2_esteig_) 32 MPI processes
>>          type: gmres
>>    PC Object: (Displacement_mg_levels_2_) 32 MPI processes
>>      type: jacobi
>>        type DIAGONAL
>>        type: mpiaij
>>        rows=45721, cols=45721
>>        total: nonzeros=9969661, allocated nonzeros=9969661
>>          using nonscalable MatPtAP() implementation
>>          not using I-node (on process 0) routines
>>    KSP Object: (Displacement_mg_levels_3_) 32 MPI processes
>>      type: chebyshev
>>        eigenvalue targets used: min 0.281318, max 3.0945
>>        eigenvalues estimated via gmres: min 0.0522027, max 2.81318
>>        KSP Object: (Displacement_mg_levels_3_esteig_) 32 MPI processes
>>          type: gmres
>>    PC Object: (Displacement_mg_levels_3_) 32 MPI processes
>>      type: jacobi
>>        type DIAGONAL
>>      Mat Object: (Displacement_) 32 MPI processes
>>        type: mpiaij
>>        rows=2186610, cols=2186610, bs=3
>>        total: nonzeros=181659996, allocated nonzeros=181659996
>>          has attached near null space
>>          using I-node (on process 0) routines: found 21368 nodes, limit
>> used is 5
>>    type: mpiaij
>>      using I-node (on process 0) routines: found 21368 nodes, limit used
>> is 5
>> cell set    1 elastic energy:  9.32425E-02 work:  1.86485E-01 total:
>> -9.32425E-02
>> Mechanics (Tier 1)
> Mechanics (Tier 1)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221214/070c2f53/attachment-0001.html>
