[petsc-users] GAMG and linearized elasticity
Mark Adams mfadams at lbl.gov
Wed Dec 14 08:20:33 CST 2022
The eigen estimator is failing in GAMG.
* The coarsening method in GAMG changed in recent releases, a little bit,
with "aggressive" or "square" coarsening (two MISs instead of MIS on A'A),
but something else is going on here.
* Your fine grid looks good, N%3 == 0 and NNZ%9 == 0, the coarse grids seem
to have lost the block size. N is not a factor of 3, or 6 with the null
space. rows=45721, cols=45721. This is bad.
* the block size is in there on the fine grid:  rows=2186610, cols=2186610,
bs=3
* Try running with -info and grep on GAMG and send me that output.
Something is very wrong here.
On Tue, Dec 13, 2022 at 10:38 PM Jed Brown <jed at jedbrown.org> wrote:
> Do you have slip/symmetry boundary conditions, where some components are
> constrained? In that case, there is no uniform block size and I think
> you'll need DMPlexCreateRigidBody() and MatSetNearNullSpace().
> The PCSetCoordinates() code won't work for non-constant block size.
> -pc_type gamg should work okay out of the box for elasticity. For hypre,
> I've had good luck with this options suite, which also runs on GPU.
> -pc_type hypre -pc_hypre_boomeramg_coarsen_type pmis
> -pc_hypre_boomeramg_interp_type ext+i -pc_hypre_boomeramg_no_CF
> -pc_hypre_boomeramg_P_max 6 -pc_hypre_boomeramg_relax_type_down Chebyshev
> -pc_hypre_boomeramg_relax_type_up Chebyshev
> -pc_hypre_boomeramg_strong_threshold 0.5
> Blaise Bourdin <bourdin at mcmaster.ca> writes:
> > Hi,
> > I am getting close to finish porting a code from petsc 3.3 / sieve to
> main / dmplex, but am
> > now encountering difficulties
> > I am reasonably sure that the Jacobian and residual are correct. The
> codes handle boundary
> > conditions differently (MatZeroRowCols vs dmplex constraints) so it is
> not trivial to compare
> > them. Running with snes_type ksponly pc_type Jacobi or hyper gives me
> the same results in
> > roughly the same number of iterations.
> > In my old code, gamg would work out of the box. When using petsc-main,
> -pc_type gamg -
> > pc_gamg_type agg works for _some_ problems using P1-Lagrange elements,
> but never for
> > P2-Lagrange. The typical error message is in gamg_agg.txt
> > When using -pc_type classical, a problem where the KSP would converge in
> 47 iteration in
> > 3.3 now takes 1400.  ksp_view_3.3.txt and ksp_view_main.txt show the
> output of -ksp_view
> > for both versions. I don’t notice anything obvious.
> > Strangely, removing the call to PCSetCoordinates does not have any
> impact on the
> > convergence.
> > I am sure that I am missing something, or not passing the right options.
> What’s a good
> > starting point for 3D elasticity?
> > Regards,
> > Blaise
> > Canada Research Chair in Mathematical and Computational Aspects of Solid
> Mechanics
> > (Tier 1)
> > Professor, Department of Mathematics & Statistics
> > Hamilton Hall room 409A, McMaster University
> > 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
> > https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Petsc has generated inconsistent data
> > [0]PETSC ERROR: Computed maximum singular value as zero
> > [0]PETSC ERROR: WARNING! There are option(s) set that were not used!
> Could be the program crashed before they were used or a spelling mistake,
> etc!
> > [0]PETSC ERROR: Option left: name:-displacement_ksp_converged_reason
> value: ascii source: file
> > [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision:
> v3.18.2-341-g16200351da0  GIT Date: 2022-12-12 23:42:20 +0000
> > [0]PETSC ERROR:
> /home/bourdinb/Development/mef90/mef90-dmplex/bbserv-gcc11.2.1-mvapich2-2.3.7-O/bin/ThermoElasticity
> on a bbserv-gcc11.2.1-mvapich2-2.3.7-O named bb01 by bourdinb Tue Dec 13
> 17:02:19 2022
> > [0]PETSC ERROR: Configure options --CFLAGS=-Wunused
> --FFLAGS="-ffree-line-length-none -fallow-argument-mismatch -Wunused"
> --COPTFLAGS="-O2 -march=znver2" --CXXOPTFLAGS="-O2 -march=znver2"
> --FOPTFLAGS="-O2 -march=znver2" --download-chaco=1 --download-exodusii=1
> --download-fblaslapack=1 --download-hdf5=1 --download-hypre=1
> --download-metis=1 --download-ml=1 --download-mumps=1 --download-netcdf=1
> --download-p4est=1 --download-parmetis=1 --download-pnetcdf=1
> --download-scalapack=1 --download-sowing=1
> --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc
> --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++
> --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp
> --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp
> --download-superlu=1 --download-triangle=1 --download-yaml=1
> --download-zlib=1 --with-debugging=0
> --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-pic
> --with-shared-libraries=1 --with-mpiexec=srun --with-x11=0
> > [0]PETSC ERROR: #1 PCGAMGOptProlongator_AGG() at
> /1/HPC/petsc/main/src/ksp/pc/impls/gamg/agg.c:779
> > [0]PETSC ERROR: #2 PCSetUp_GAMG() at
> /1/HPC/petsc/main/src/ksp/pc/impls/gamg/gamg.c:639
> > [0]PETSC ERROR: #3 PCSetUp() at
> /1/HPC/petsc/main/src/ksp/pc/interface/precon.c:994
> > [0]PETSC ERROR: #4 KSPSetUp() at
> /1/HPC/petsc/main/src/ksp/ksp/interface/itfunc.c:405
> > [0]PETSC ERROR: #5 KSPSolve_Private() at
> /1/HPC/petsc/main/src/ksp/ksp/interface/itfunc.c:824
> > [0]PETSC ERROR: #6 KSPSolve() at
> /1/HPC/petsc/main/src/ksp/ksp/interface/itfunc.c:1070
> > [0]PETSC ERROR: #7 SNESSolve_KSPONLY() at
> /1/HPC/petsc/main/src/snes/impls/ksponly/ksponly.c:48
> > [0]PETSC ERROR: #8 SNESSolve() at
> /1/HPC/petsc/main/src/snes/interface/snes.c:4693
> > [0]PETSC ERROR: #9
> /home/bourdinb/Development/mef90/mef90-dmplex/ThermoElasticity/ThermoElasticity.F90:228
> >   Linear solve converged due to CONVERGED_RTOL iterations 46
> > KSP Object:(Disp_) 32 MPI processes
> >   type: cg
> >   maximum iterations=10000
> >   tolerances:  relative=1e-05, absolute=1e-08, divergence=1e+10
> >   left preconditioning
> >   using nonzero initial guess
> >   using PRECONDITIONED norm type for convergence test
> > PC Object:(Disp_) 32 MPI processes
> >   type: gamg
> >     MG: type is MULTIPLICATIVE, levels=4 cycles=v
> >       Cycles per PCApply=1
> >       Using Galerkin computed coarse grid matrices
> >   Coarse grid solver -- level -------------------------------
> >     KSP Object:    (Disp_mg_coarse_)     32 MPI processes
> >       type: gmres
> >         GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >         GMRES: happy breakdown tolerance 1e-30
> >       maximum iterations=1, initial guess is zero
> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
> >       using NONE norm type for convergence test
> >     PC Object:    (Disp_mg_coarse_)     32 MPI processes
> >       type: bjacobi
> >         block Jacobi: number of blocks = 32
> >         Local solve info for each block is in the following KSP and PC
> objects:
> >       [0] number of local blocks = 1, first local block number = 0
> >         [0] local block number 0
> >         KSP Object:        (Disp_mg_coarse_sub_)         1 MPI processes
> >           type: preonly
> >           maximum iterations=10000, initial guess is zero
> >         PC Object:        (Disp_mg_coarse_sub_)         1 MPI processes
> >           type: lu
> >           type: preonly
> >             LU: out-of-place factorization
> >             tolerance for zero pivot 2.22045e-14
> >             matrix ordering: nd
> >             factor fill ratio given 5, needed 1.06061
> >               Factored matrix follows:
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >             factor fill ratio given 5, needed 0
> >                 Matrix Object:                 1 MPI processes
> >           type: preonly
> >           type: lu
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> >                   rows=0, cols=0, bs=6
> >                   package used to perform factorization: petsc
> >                   total: nonzeros=1, allocated nonzeros=1
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> >                   total number of mallocs used during MatSetValues calls
> =0
> >                     not using I-node routines
> >           linear system matrix = precond matrix:
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >             total: nonzeros=0, allocated nonzeros=0
> >             total number of mallocs used during MatSetValues calls =0
> >                   type: seqaij
> >                   rows=54, cols=54, bs=6
> >                   total: nonzeros=1260, allocated nonzeros=1260
> =0
> >                     using I-node routines: found 16 nodes, limit used is
> 5
> >             type: seqaij
> >             total: nonzeros=1188, allocated nonzeros=1188
> >               using I-node routines: found 17 nodes, limit used is 5
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> =0
> >             type: seqaij
> >             type: seqaij
> >             type: seqaij
> >           type: preonly
> >           type: preonly
> >           type: lu
> >           type: preonly
> >           type: lu
> >           type: lu
> >             matrix ordering: nd
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >             matrix ordering: nd
> >                   type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >       [1] number of local blocks = 1, first local block number = 1
> >         [1] local block number 0
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >                   type: seqaij
> =0
> >             type: seqaij
> >           type: preonly
> >           type: lu
> >             matrix ordering: nd
> >                   type: seqaij
> =0
> >             type: seqaij
> >       [2] number of local blocks = 1, first local block number = 2
> >         [2] local block number 0
> >       [3] number of local blocks = 1, first local block number = 3
> >         [3] local block number 0
> >       [4] number of local blocks = 1, first local block number = 4
> >         [4] local block number 0
> >       [5] number of local blocks = 1, first local block number = 5
> >         [5] local block number 0
> >       [6] number of local blocks = 1, first local block number = 6
> >         [6] local block number 0
> >       [7] number of local blocks = 1, first local block number = 7
> >         [7] local block number 0
> >       [8] number of local blocks = 1, first local block number = 8
> >         [8] local block number 0
> >       [9] number of local blocks = 1, first local block number = 9
> >         [9] local block number 0
> >       [10] number of local blocks = 1, first local block number = 10
> >         [10] local block number 0
> >       [11] number of local blocks = 1, first local block number = 11
> >         [11] local block number 0
> >       [12] number of local blocks = 1, first local block number = 12
> >         [12] local block number 0
> >       [13] number of local blocks = 1, first local block number = 13
> >         [13] local block number 0
> >       [14] number of local blocks = 1, first local block number = 14
> >         [14] local block number 0
> >       [15] number of local blocks = 1, first local block number = 15
> >         [15] local block number 0
> >       [16] number of local blocks = 1, first local block number = 16
> >         [16] local block number 0
> >       [17] number of local blocks = 1, first local block number = 17
> >         [17] local block number 0
> >       [18] number of local blocks = 1, first local block number = 18
> >         [18] local block number 0
> >       [19] number of local blocks = 1, first local block number = 19
> >         [19] local block number 0
> >       [20] number of local blocks = 1, first local block number = 20
> >         [20] local block number 0
> >       [21] number of local blocks = 1, first local block number = 21
> >         [21] local block number 0
> >       [22] number of local blocks = 1, first local block number = 22
> >         [22] local block number 0
> >       [23] number of local blocks = 1, first local block number = 23
> >         [23] local block number 0
> >       [24] number of local blocks = 1, first local block number = 24
> >         [24] local block number 0
> >       [25] number of local blocks = 1, first local block number = 25
> >         [25] local block number 0
> >       [26] number of local blocks = 1, first local block number = 26
> >         [26] local block number 0
> >       [27] number of local blocks = 1, first local block number = 27
> >         [27] local block number 0
> >       [28] number of local blocks = 1, first local block number = 28
> >         [28] local block number 0
> >       [29] number of local blocks = 1, first local block number = 29
> >         [29] local block number 0
> >       [30] number of local blocks = 1, first local block number = 30
> >         [30] local block number 0
> >       [31] number of local blocks = 1, first local block number = 31
> >         [31] local block number 0
> >       Matrix Object:       32 MPI processes
> >         type: mpiaij
> >           using I-node (on process 0) routines: found 17 nodes, limit
> used is 5
> >   Down solver (pre-smoother) on level 1 -------------------------------
> >     KSP Object:    (Disp_mg_levels_1_)     32 MPI processes
> >       type: chebyshev
> >         Chebyshev: eigenvalue estimates:  min = 0.101023, max = 2.13327
> >       maximum iterations=2
> >     PC Object:    (Disp_mg_levels_1_)     32 MPI processes
> >       type: jacobi
> >         type: mpiaij
> >         rows=1086, cols=1086, bs=6
> >         total: nonzeros=67356, allocated nonzeros=67356
> >           using I-node (on process 0) routines: found 362 nodes, limit
> used is 5
> >   Up solver (post-smoother) same as down solver (pre-smoother)
> >   Down solver (pre-smoother) on level 2 -------------------------------
> >     KSP Object:    (Disp_mg_levels_2_)     32 MPI processes
> >       type: chebyshev
> >         Chebyshev: eigenvalue estimates:  min = 0.0996526, max = 2.29388
> >     PC Object:    (Disp_mg_levels_2_)     32 MPI processes
> >       type: jacobi
> >         type: mpiaij
> >         rows=23808, cols=23808, bs=6
> >         total: nonzeros=1976256, allocated nonzeros=1976256
> >           using I-node (on process 0) routines: found 7936 nodes, limit
> used is 5
> >   Down solver (pre-smoother) on level 3 -------------------------------
> >     KSP Object:    (Disp_mg_levels_3_)     32 MPI processes
> >       type: chebyshev
> >         Chebyshev: eigenvalue estimates:  min = 0.165968, max = 2.13065
> >     PC Object:    (Disp_mg_levels_3_)     32 MPI processes
> >       type: jacobi
> >       Matrix Object:      (Disp_)       32 MPI processes
> >         type: mpiaij
> >         rows=291087, cols=291087
> >         total: nonzeros=12323691, allocated nonzeros=12336696
> >           using I-node (on process 0) routines: found 3419 nodes, limit
> used is 5
> >     type: mpiaij
> >       using I-node (on process 0) routines: found 3419 nodes, limit used
> is 5
> >  SNESConvergedReason returned            5
> > KSP Object: (Displacement_) 32 MPI processes
> >   type: cg
> >   maximum iterations=10000, nonzero initial guess
> > PC Object: (Displacement_) 32 MPI processes
> >   type: gamg
> >       Using externally compute Galerkin coarse grid matrices
> >       GAMG specific options
> >         Threshold for dropping small values in graph on each level =
>  -1.   -1.   -1.   -1.
> >         Threshold scaling factor for each level not specified = 1.
> >         Complexity:    grid = 1.02128    operator = 1.05534
> >   Coarse grid solver -- level 0 -------------------------------
> >     KSP Object: (Displacement_mg_coarse_) 32 MPI processes
> >       type: preonly
> >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
> >     PC Object: (Displacement_mg_coarse_) 32 MPI processes
> >       type: bjacobi
> >         Local solver information for first block is in the following KSP
> and PC objects on rank 0:
> >         Use -Displacement_mg_coarse_ksp_view ::ascii_info_detail to
> display information for all blocks
> >       KSP Object: (Displacement_mg_coarse_sub_) 1 MPI process
> >         type: preonly
> >       PC Object: (Displacement_mg_coarse_sub_) 1 MPI process
> >         type: lu
> >           using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> >           matrix ordering: nd
> >           factor fill ratio given 5., needed 1.08081
> >               Mat Object: (Displacement_mg_coarse_sub_) 1 MPI process
> >                 type: seqaij
> >                 rows=20, cols=20
> >                 total: nonzeros=214, allocated nonzeros=214
> >                   using I-node routines: found 8 nodes, limit used is 5
> >           type: seqaij
> >           rows=20, cols=20
> >           total: nonzeros=198, allocated nonzeros=198
> >           total number of mallocs used during MatSetValues calls=0
> >             using I-node routines: found 13 nodes, limit used is 5
> >       Mat Object: 32 MPI processes
> >         type: mpiaij
> >         rows=20, cols=20
> >           using I-node (on process 0) routines: found 13 nodes, limit
> used is 5
> >     KSP Object: (Displacement_mg_levels_1_) 32 MPI processes
> >       type: chebyshev
> >         eigenvalue targets used: min 0.81922, max 9.01143
> >         eigenvalues estimated via gmres: min 0.186278, max 8.1922
> >         eigenvalues estimated using gmres with transform: [0. 0.1; 0.
> 1.1]
> >         KSP Object: (Displacement_mg_levels_1_esteig_) 32 MPI processes
> >           type: gmres
> >           maximum iterations=10, initial guess is zero
> >           tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
> >         estimating eigenvalues using noisy right hand side
> >       maximum iterations=2, nonzero initial guess
> >     PC Object: (Displacement_mg_levels_1_) 32 MPI processes
> >       type: jacobi
> >         type DIAGONAL
> >         type: mpiaij
> >         rows=799, cols=799
> >         total: nonzeros=83159, allocated nonzeros=83159
> >           using I-node (on process 0) routines: found 23 nodes, limit
> used is 5
> >     KSP Object: (Displacement_mg_levels_2_) 32 MPI processes
> >       type: chebyshev
> >         eigenvalue targets used: min 1.16291, max 12.792
> >         eigenvalues estimated via gmres: min 0.27961, max 11.6291
> 1.1]
> >         KSP Object: (Displacement_mg_levels_2_esteig_) 32 MPI processes
> >           type: gmres
> >     PC Object: (Displacement_mg_levels_2_) 32 MPI processes
> >       type: jacobi
> >         type DIAGONAL
> >         type: mpiaij
> >         total: nonzeros=9969661, allocated nonzeros=9969661
> >           using nonscalable MatPtAP() implementation
> >           not using I-node (on process 0) routines
> >     KSP Object: (Displacement_mg_levels_3_) 32 MPI processes
> >       type: chebyshev
> >         eigenvalue targets used: min 0.281318, max 3.0945
> >         eigenvalues estimated via gmres: min 0.0522027, max 2.81318
> 1.1]
> >         KSP Object: (Displacement_mg_levels_3_esteig_) 32 MPI processes
> >           type: gmres
> >     PC Object: (Displacement_mg_levels_3_) 32 MPI processes
> >       type: jacobi
> >         type DIAGONAL
> >       Mat Object: (Displacement_) 32 MPI processes
> >         type: mpiaij
> >         rows=2186610, cols=2186610, bs=3
> >         total: nonzeros=181659996, allocated nonzeros=181659996
> >           has attached near null space
> >           using I-node (on process 0) routines: found 21368 nodes, limit
> used is 5
> >     type: mpiaij
> used is 5
> > cell set    1 elastic energy:  9.32425E-02 work:  1.86485E-01 total:
> -9.32425E-02
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221214/cc34d186/attachment-0001.html>
