[petsc-users] Saving solution with monitor function
Barry Smith bsmith at petsc.dev
Tue Dec 13 11:55:53 CST 2022
  It is also possible to read the solutions back from the trajectory object from your running code. It is not just for saving to files.
> On Dec 13, 2022, at 12:51 PM, Zhang, Hong via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Tyler,
> The quickest solution is to use TSTrajectory as Matt mentioned. You can add the following command line options to save the solution into a binary file under a folder at each time step.
> -ts_save_trajectory -ts_trajectory_type visualization
> The folder name and the file name can be customized with -ts_trajectory_dirname and -ts_trajectory_file_template.
> If you want to load these files into Matlab, you can use some scripts in share/petsc/matlab/ such as PetscReadBinaryTrajectory.m and PetscBinaryRead.m.
> The python versions of these scripts are available in lib/petsc/bin/.
> Hong(Mr.)
>> On Dec 13, 2022, at 12:14 AM, Guglielmo, Tyler Hardy via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> Hi all,
>> I am a new PETSc user (and new to MPI in general), and was wondering if someone could help me out with what I am sure is a basic question (if this is not the appropriate email list or there is a better place please let me know!).
>> Basically, I am writing a code that requires a solution to an ODE that will be used later on during runtime.  I have written the basic ODE solver using TSRK, however I haven’t thought of a good way to store the actual solution at all time steps throughout the time evolution.  I would like to avoid writing each time step to a file through the monitor function, and instead just plug each time step into an array.
>> How is this usually done?  I suppose the user defined struct that gets passed into the monitor function could contain a pointer to an array in main?  This is how I would do this if the program wasn’t of the MPI variety, but I am not sure how to properly declare a pointer to an array declared as Vec and built through the usual PETSc process.  Any tips are greatly appreciated!
>> Thanks for your time,
>> Tyler
>> Tyler Guglielmo
>> Postdoctoral Researcher
>> Lawrence Livermore National Lab
>> Office: 925-423-6186
>> Cell: 210-480-8000
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/e1c10a8b/attachment-0001.html>
