[petsc-users] Fortran Interface NULL object / Casting
    Barry Smith
    bsmith at petsc.dev
    Thu Dec  8 13:56:16 CST 2022
   You would use PETSC_NULL_DMLABEL but Matt needs to customize the PETSc Fortran stub for DMAddField() for you to handle accepting the NULL from PETSc.
   Barry
> On Dec 8, 2022, at 1:05 PM, Nicholas Arnold-Medabalimi <narnoldm at umich.edu> wrote:
> Hi Petsc Users
> I am trying to use DMAddField in a Fortran code. I had some questions on casting/passing NULL. I follow how to pass NULL for standard types (INT, CHAR, etc).
> Is there a method/best practice for passing NULL for Petsc type arguments? (In this case DMAddLabel I'd want to pass NULL to a DMLabel Parameter not an intrinsic type)
> For the 2nd question, In some cases in C we would cast a more specific object to Petsc Object
> DMAddField(dm, NULL, (PetscObject)fvm); (where fvm is a PetscFVM type)
> Is there a method or practice to do the same in Fortran.
> Thanks
> Nicholas
> Ph.D. Candidate
> Computational Aeroscience Lab
> University of Michigan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221208/27855938/attachment.html>
