[petsc-users] Petsc Section in DMPlex
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Thu Dec 8 09:48:27 CST 2022
Hi Matt
Thanks. Found the issue just messed up the Fortran to C indexing.
Another question. I have been using the Petsc VTK output to view things. In
some previous efforts, I used the PetscFVM object to set up my section
data. When I output vectors using that method in ParaView, I could view the
rank information and the state vector to visualize. As far as I can tell
when I do the same with Vectors that were created with my manually created
section the VecView using PETSCVIEWERVTK only mesh is output with the Rank
distribution is viewable (basically as if I had done a DM output instead of
a Vec output). My guess is this is because I'm not setting something in my
section Field setup properly for the VTK viewer to output it?
For my section set up, I am calling
PetscSectionCreate
PetscSectionSetChart
PetscSectionSetFieldName
and then the appropriate PetscSectionSetDof
PetscSectionSetup
DMSetLocalSection
Thanks again for all the help.
Sincerely
Nicholas
On Thu, Dec 8, 2022 at 7:27 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Dec 8, 2022 at 3:04 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Matt
>> I think I've gotten it just about there. I'm just having an issue with
>> the VecISCopy. I have an IS built that matches size correctly to map from
>> the full state to the filtered state. The core issue I think, is should the
>> expanded IS the ownership range of the vector subtracted out. Looking at
>> the implementation, it looks like VecISCopy takes care of that for me.
>> (Line 573 in src/vec/vec/utils/projection.c) But I could be mistaken.
> It is a good question. We have tried to give guidance on the manpage:
> The index set identifies entries in the global vector. Negative indices
> are skipped; indices outside the ownership range of vfull will raise an
> error.
> which means that it expects _global_ indices, and you have retrieved the
> global section, so that matches.
> The calculation of the index size looks right to me, and so does the index
> calculation.
> I would put a check in the loop, making sure that the calculated indices
> lie within [oStart, oEnd). The global
> section is designed to ensure that. It is not clear why one would lie
> outside.
> When I am debugging, I run a very small problem, and print out all the
> sections.
> Thanks,
> Matt
>> The error I am getting is:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: No support for this operation for this object type
>> [0]PETSC ERROR: Only owned values supported
>> Here is what I am currently doing.
>> call DMPlexFilter(dmplex_full, iBlankLabel, 1, dmplex_filtered,ierr)
>> call DMPlexGetSubpointIS(dmplex_filtered, subpointsIS,ierr)
>> ! adds section to dmplex_filtered and allocates vec_filtered using
>> DMCreateGlobalVector
>> call addSectionToDMPlex(dmplex_filtered,vec_filtered)
>> ! Get Sections for dmplex_filtered and dmplex_full
>> call DMGetGlobalSection(dmplex_filtered,filteredfieldSection,ierr)
>> call DMGetGlobalSection(dmplex_full,fullfieldSection,ierr)
>> call ISGetIndicesF90(subpointsIS, subPointKey,ierr)
>> ExpandedIndexSize = 0
>> do i = 1, size(subPointKey)
>> call PetscSectionGetDof(fullfieldSection, subPointKey(i), dof,ierr)
>> ExpandedIndexSize = ExpandedIndexSize + dof
>> enddo
>> !Create expandedIS from offset sections of full and filtered sections
>> allocate(ExpandedIndex(ExpandedIndexSize))
>> call VecGetOwnershipRange(vec_full,oStart,oEnd,ierr)
>> call PetscSectionGetOffset(fullfieldSection, subPointKey(i),
>> offset,ierr)
>> !offset=offset-oStart !looking at VecIScopy it takes care of this
>> subtraction (not sure)
>> do j = 1, (dof)
>> ExpandedIndex((i-1)*dof+j) = offset+j
>> end do
>> enddo
>> call ISCreateGeneral(PETSC_COMM_WORLD, ExpandedIndexSize, ExpandedIndex,
>> PETSC_COPY_VALUES, expandedIS,ierr)
>> call ISRestoreIndicesF90(subpointsIS, subPointKey,ierr)
>> deallocate(ExpandedIndex)
>> call VecGetLocalSize(vec_full,sizeVec,ierr)
>> write(*,*) sizeVec
>> call VecGetLocalSize(vec_filtered,sizeVec,ierr)
>> write(*,*) sizeVec
>> call ISGetLocalSize(expandedIS,sizeVec,ierr)
>> write(*,*) sizeVec
>> call PetscSynchronizedFlush(PETSC_COMM_WORLD,ierr)
>> call VecISCopy(vec_full,expandedIS,SCATTER_REVERSE,vec_filtered,ierr)
>> Thanks again for the great help.
>> Sincerely
>> Nicholas
>> On Wed, Dec 7, 2022 at 9:29 PM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Wed, Dec 7, 2022 at 9:21 PM Nicholas Arnold-Medabalimi <
>>>> Thank you for the help.
>>>> I think the last piece of the puzzle is how do I create the "expanded
>>>> IS" from the subpoint IS using the section?
>>> Loop over the points in the IS. For each point, get the dof and offset
>>> from the Section. Make a new IS that has all the
>>> dogs, namely each run [offset, offset+dof).
>>> Thanks,
>>> Matt
>>>> Sincerely
>>>> Nicholas
>>>> On Wed, Dec 7, 2022 at 7:06 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Dec 7, 2022 at 6:51 AM Nicholas Arnold-Medabalimi <
>>>>>> Hi
>>>>>> Thank you so much for your patience. One thing to note: I don't have
>>>>>> any need to go back from the filtered distributed mapping back to the full
>>>>>> but it is good to know.
>>>>>> One aside question.
>>>>>> 1) Is natural and global ordering the same in this context?
>>>>> No.
>>>>>> As far as implementing what you have described.
>>>>>> When I call ISView on the generated SubpointIS, I get an unusual
>>>>>> error which I'm not sure how to interpret. (this case is running on 2 ranks
>>>>>> and the filter label has points located on both ranks of the original DM.
>>>>>> However, if I manually get the indices (the commented lines), it seems to
>>>>>> not have any issues.
>>>>>> !call ISGetIndicesF90(subpointsIS, subPointKey,ierr)
>>>>>> !write(*,*) subPointKey
>>>>>> !call ISRestoreIndicesF90(subpointsIS, subPointKey,ierr)
>>>>>> call ISView(subpointsIS,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>>>>> [1]PETSC ERROR: --------------------- Error Message
>>>>>> [1]PETSC ERROR: Arguments must have same communicators
>>>>>> [1]PETSC ERROR: Different communicators in the two objects: Argument
>>>>>> # 1 and 2 flag 3
>>>>>> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>> shooting.
>>>>>> [1]PETSC ERROR: Petsc Development GIT revision:
>>>>>> v3.18.1-320-g7810d690132 GIT Date: 2022-11-20 20:25:41 -0600
>>>>>> [1]PETSC ERROR: Configure options with-fc=mpiifort
>>>>>> with-mpi-f90=mpiifort --download-triangle --download-parmetis
>>>>>> --download-metis --with-debugging=1 --download-hdf5
>>>>>> --prefix=/home/narnoldm/packages/petsc_install
>>>>>> [1]PETSC ERROR: #1 ISView() at
>>>>>> /home/narnoldm/packages/petsc/src/vec/is/is/interface/index.c:1629
>>>>> The problem here is the subpointsIS is a _serial_ object, and you are
>>>>> using a parallel viewer. You can use PETSC_VIEWER_STDOUT_SELF,
>>>>> or you can pull out the singleton viewer from STDOUT_WORLD if you want
>>>>> them all to print in order.
>>>>>> As far as the overall process you have described my question on first
>>>>>> glance is do I have to allocate/create the vector that is output by
>>>>>> VecISCopy before calling it, or does it create the vector automatically?
>>>>> You create both vectors. I would do it using DMCreateGlobalVector()
>>>>> from both DMs.
>>>>>> I think I would need to create it first using a section and Setting
>>>>>> the Vec in the filtered DM?
>>>>> Setting the Section in the filtered DM.
>>>>>> And I presume in this case I would be using the scatter reverse
>>>>>> option to go from the full set to the reduced set?
>>>>> Yes
>>>>> Thanks
>>>>> Matt
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> Sincerely
>>>>>> Nick
>>>>>> On Wed, Dec 7, 2022 at 6:00 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Dec 7, 2022 at 3:35 AM Nicholas Arnold-Medabalimi <
>>>>>>>> Hi Matthew
>>>>>>>> Thank you for the help. This clarified a great deal.
>>>>>>>> I have a follow-up question related to DMPlexFilter. It may be
>>>>>>>> better to describe what I'm trying to achieve.
>>>>>>>> I have a general mesh I am solving which has a section with cell
>>>>>>>> center finite volume states, as described in my initial email. After
>>>>>>>> calculating some metrics, I tag a bunch of cells with an identifying Label
>>>>>>>> and use DMFilter to generate a new DM which is only that subset of cells.
>>>>>>>> Generally, this leads to a pretty unbalanced DM so I then plan to use
>>>>>>>> DMPlexDIstribute to balance that DM across the processors. The coordinates
>>>>>>>> pass along fine, but the state(or I should say Section) does not at least
>>>>>>>> as far as I can tell.
>>>>>>>> Assuming I can get a filtered DM I then distribute the DM and state
>>>>>>>> using the method you described above and it seems to be working ok.
>>>>>>>> The last connection I have to make is the transfer of information
>>>>>>>> from the full mesh to the "sampled" filtered mesh. From what I can gather I
>>>>>>>> would need to get the mapping of points using DMPlexGetSubpointIS and then
>>>>>>>> manually copy the values from the full DM section to the filtered DM? I
>>>>>>>> have the process from full->filtered->distributed all working for the
>>>>>>>> coordinates so its just a matter of transferring the section correctly.
>>>>>>>> I appreciate all the help you have provided.
>>>>>>> Let's do this in two steps, which makes it easier to debug. First,
>>>>>>> do not redistribute the submesh. Just use DMPlexGetSubpointIS()
>>>>>>> to get the mapping of filtered points to points in the original
>>>>>>> mesh. Then create an expanded IS using the Section which makes
>>>>>>> dofs in the filtered mesh to dofs in the original mesh. From this use
>>>>>>> https://petsc.org/main/docs/manualpages/Vec/VecISCopy/
>>>>>>> to move values between the original vector and the filtered vector.
>>>>>>> Once that works, you can try redistributing the filtered mesh.
>>>>>>> Before calling DMPlexDistribute() on the filtered mesh, you need to call
>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural/
>>>>>>> When you redistribute, it will compute a mapping back to the
>>>>>>> original layout. Now when you want to transfer values, you
>>>>>>> 1) Create a natural vector with DMCreateNaturalVec()
>>>>>>> 2) Use DMGlobalToNaturalBegin/End() to move values from the
>>>>>>> filtered vector to the natural vector
>>>>>>> 3) Use VecISCopy() to move values from the natural vector to the
>>>>>>> original vector
>>>>>>> Let me know if you have any problems.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Sincerely
>>>>>>>> Nicholas
>>>>>>>> On Mon, Nov 28, 2022 at 6:19 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Sun, Nov 27, 2022 at 10:22 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>> Hi Petsc Users
>>>>>>>>>> I have a question about properly using PetscSection to
>>>>>>>>>> assign state variables to a DM. I have an existing DMPlex mesh distributed
>>>>>>>>>> on 2 processors. My goal is to have state variables set to the cell
>>>>>>>>>> centers. I then want to call DMPlexDistribute, which I hope will balance
>>>>>>>>>> the mesh elements and hopefully transport the state variables to the
>>>>>>>>>> hosting processors as the cells are distributed to a different processor
>>>>>>>>>> count or simply just redistributing after doing mesh adaption.
>>>>>>>>>> Looking at the DMPlex User guide, I should be able to achieve
>>>>>>>>>> this with a single field section using SetDof and assigning the DOF to the
>>>>>>>>>> points corresponding to cells.
>>>>>>>>> Note that if you want several different fields, you can clone the
>>>>>>>>> DM first for this field
>>>>>>>>> call DMClone(dm,dmState,ierr)
>>>>>>>>> and use dmState in your calls below.
>>>>>>>>>> call DMPlexGetHeightStratum(dm,0,c0,c1,ierr)
>>>>>>>>>> call DMPlexGetChart(dm,p0,p1,ierr)
>>>>>>>>>> call PetscSectionCreate(PETSC_COMM_WORLD,section,ierr)
>>>>>>>>>> call PetscSectionSetNumFields(section,1,ierr) call
>>>>>>>>>> PetscSectionSetChart(section,p0,p1,ierr)
>>>>>>>>>> do i = c0, (c1-1)
>>>>>>>>>> call PetscSectionSetDof(section,i,nvar,ierr)
>>>>>>>>>> end do
>>>>>>>>>> call PetscSectionSetup(section,ierr)
>>>>>>>>>> call DMSetLocalSection(dm,section,ierr)
>>>>>>>>> In the loop, I would add a call to
>>>>>>>>> call PetscSectionSetFieldDof(section,i,0,nvar,ierr)
>>>>>>>>> This also puts in the field breakdown. It is not essential, but
>>>>>>>>> nicer.
>>>>>>>>>> From here, it looks like I can access and set the state vars
>>>>>>>>>> using
>>>>>>>>>> call DMGetGlobalVector(dmplex,state,ierr)
>>>>>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>>>>>> call VecGetArrayF90(state,stateVec,ierr)
>>>>>>>>>> do i = c0, (c1-1)
>>>>>>>>>> call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>>>>>> stateVec(offset:(offset+nvar))=state_i(:) !simplified assignment
>>>>>>>>>> end do
>>>>>>>>>> call VecRestoreArrayF90(state,stateVec,ierr)
>>>>>>>>>> call DMRestoreGlobalVector(dmplex,state,ierr)
>>>>>>>>>> To my understanding, I should be using Global vector since this
>>>>>>>>>> is a pure assignment operation and I don't need the ghost cells.
>>>>>>>>> Yes.
>>>>>>>>> But the behavior I am seeing isn't exactly what I'd expect.
>>>>>>>>>> To be honest, I'm somewhat unclear on a few things
>>>>>>>>>> 1) Should be using nvar fields with 1 DOF each or 1 field with
>>>>>>>>>> nvar DOFs or what the distinction between the two methods are?
>>>>>>>>> We have two divisions in a Section. A field can have a number of
>>>>>>>>> components. This is intended to model a vector or tensor field.
>>>>>>>>> Then a Section can have a number of fields, such as velocity and
>>>>>>>>> pressure for a Stokes problem. The division is mainly to help the
>>>>>>>>> user, so I would use the most natural one.
>>>>>>>>>> 2) Adding a print statement after the offset assignment I get (on
>>>>>>>>>> rank 0 of 2)
>>>>>>>>>> cell 1 offset 0
>>>>>>>>>> cell 2 offset 18
>>>>>>>>>> cell 3 offset 36
>>>>>>>>>> which is expected and works but on rank 1 I get
>>>>>>>>>> cell 1 offset 9000
>>>>>>>>>> cell 2 offset 9018
>>>>>>>>>> cell 3 offset 9036
>>>>>>>>>> which isn't exactly what I would expect. Shouldn't the offsets
>>>>>>>>>> reset at 0 for the next rank?
>>>>>>>>> The local and global sections hold different information. This is
>>>>>>>>> the source of the confusion. The local section does describe a local
>>>>>>>>> vector, and thus includes overlap or "ghost" dofs. The global
>>>>>>>>> section describes a global vector. However, it is intended to deliver
>>>>>>>>> global indices, and thus the offsets give back global indices.
>>>>>>>>> When you use VecGetArray*() you are getting out the local array, and
>>>>>>>>> thus you have to subtract the first index on this process. You can
>>>>>>>>> get that from
>>>>>>>>> VecGetOwnershipRange(v, &rstart, &rEnd);
>>>>>>>>> This is the same whether you are using DMDA or DMPlex or any other
>>>>>>>>> DM.
>>>>>>>>>> 3) Does calling DMPlexDistribute also distribute the section data
>>>>>>>>>> associated with the DOF, based on the description in DMPlexDistribute it
>>>>>>>>>> looks like it should?
>>>>>>>>> No. By default, DMPlexDistribute() only distributes coordinate
>>>>>>>>> data. I you want to distribute your field, it would look something like
>>>>>>>>> this:
>>>>>>>>> DMPlexDistribute(dm, 0, &sfDist, &dmDist);
>>>>>>>>> VecCreate(comm, &stateDist);
>>>>>>>>> VecSetDM(sateDist, dmDist);
>>>>>>>>> PetscSectionCreate(comm §ionDist);
>>>>>>>>> DMSetLocalSection(dmDist, sectionDist);
>>>>>>>>> DMPlexDistributeField(dmDist, sfDist, section, state, sectionDist,
>>>>>>>>> stateDist);
>>>>>>>>> We do this in src/dm/impls/plex/tests/ex36.c
>>>>>>>>> THanks,
>>>>>>>>> Matt
>>>>>>>>> I'd appreciate any insight into the specifics of this usage. I
>>>>>>>>>> expect I have a misconception on the local vs global section. Thank you.
>>>>>>>>>> Sincerely
>>>>>>>>>> Nicholas
>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>> University of Michigan
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>> Ph.D. Candidate
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> Ph.D. Candidate
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Ph.D. Candidate
>>> experiments lead.
>>> -- Norbert Wiener
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221208/ff32a4ff/attachment-0001.html>
