[petsc-users] About MPIRUN
Matthew Knepley
knepley at gmail.com
Wed Dec 7 04:50:33 CST 2022
On Wed, Dec 7, 2022 at 5:03 AM 김성익 <ksi2443 at gmail.com> wrote:
> This error was caused by the inconsistent index of vecgetvalues in the
> mpirun case.
> For example, for the problem that the global vector size is 4, when mpirun
> -np 2, the value obtained from each process with vecgetvalues should be 2,
> but in my code tried to get 4 values, so it became a problem.
> How to solve this problem?
> I want to get a scalar array so that all process array has the same value
> with global vector size and values.
This is a fundamentally nonscalable operation. Are you sure you want to do
this?
If so, you can use
https://petsc.org/main/docs/manualpages/PetscSF/VecScatterCreateToZero/
Thanks
Matt
> Thanks,
> Hyung Kim
> 2022년 12월 7일 (수) 오후 1:34, 김성익 <ksi2443 at gmail.com>님이 작성:
>> I already done VecAssemblyBegin/End().
>> However, only mpirun case these outputs are represented.
>> There are more error outputs as below.
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>> with errorcode 73.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> [ubuntu:02473] PMIX ERROR: UNREACHABLE in file
>> ../../../src/server/pmix_server.c at line 2193
>> [ubuntu:02473] 3 more processes have sent help message help-mpi-api.txt /
>> mpi-abort
>> [ubuntu:02473] Set MCA parameter "orte_base_help_aggregate" to 0 to see
>> all help / error messages
>> Could this be the cause of the former petsc error??
>> Thanks,
>> Hyung Kim
>> 2022년 12월 6일 (화) 오후 10:58, Matthew Knepley <knepley at gmail.com>님이 작성:
>>> On Tue, Dec 6, 2022 at 6:45 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>> Hello,
>>>> There is a code which can run in not mpirun and also it can run in
>>>> mpi_linear_solver_server.
>>>> However, it has an error in just mpirun case such as mpirun -np
>>>> ./program.
>>>> The error output is as below.
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Object is in wrong state
>>>> [0]PETSC ERROR: Not for unassembled vector
>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>> shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.18.1, unknown
>>>> [0]PETSC ERROR: ./app on a arch-linux-c-debug named ubuntu by ksi2443
>>>> Tue Dec 6 03:39:13 2022
>>>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>>>> -download-parmetis -download-metis
>>>> [0]PETSC ERROR: #1 VecCopy() at
>>>> /home/ksi2443/petsc/src/vec/vec/interface/vector.c:1625
>>>> [0]PETSC ERROR: #2 KSPInitialResidual() at
>>>> /home/ksi2443/petsc/src/ksp/ksp/interface/itres.c:60
>>>> [0]PETSC ERROR: #3 KSPSolve_GMRES() at
>>>> /home/ksi2443/petsc/src/ksp/ksp/impls/gmres/gmres.c:227
>>>> [0]PETSC ERROR: #4 KSPSolve_Private() at
>>>> /home/ksi2443/petsc/src/ksp/ksp/interface/itfunc.c:899
>>>> [0]PETSC ERROR: #5 KSPSolve() at
>>>> /home/ksi2443/petsc/src/ksp/ksp/interface/itfunc.c:1071
>>>> [0]PETSC ERROR: #6 main() at /home/ksi2443/Downloads/coding/a1.c:450
>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>>> error message to petsc-maint at mcs.anl.gov----------
>>>> How can I fix this??
>>> It looks like we do not check the assembled state in parallel, since it
>>> cannot cause a problem, but every time you
>>> update values with VecSetValues(), you should call
>>> Thanks
>>> Matt
>>>> Thanks,
>>>> Hyung Kim
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221207/c6c64d0a/attachment-0001.html>
