[petsc-users] Petsc Section in DMPlex
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Wed Dec 7 02:34:43 CST 2022
Hi Matthew
Thank you for the help. This clarified a great deal.
I have a follow-up question related to DMPlexFilter. It may be better to
describe what I'm trying to achieve.
I have a general mesh I am solving which has a section with cell center
finite volume states, as described in my initial email. After calculating
some metrics, I tag a bunch of cells with an identifying Label and use
DMFilter to generate a new DM which is only that subset of cells.
Generally, this leads to a pretty unbalanced DM so I then plan to use
DMPlexDIstribute to balance that DM across the processors. The coordinates
pass along fine, but the state(or I should say Section) does not at least
as far as I can tell.
Assuming I can get a filtered DM I then distribute the DM and state using
the method you described above and it seems to be working ok.
The last connection I have to make is the transfer of information from the
full mesh to the "sampled" filtered mesh. From what I can gather I would
need to get the mapping of points using DMPlexGetSubpointIS and then
manually copy the values from the full DM section to the filtered DM? I
have the process from full->filtered->distributed all working for the
coordinates so its just a matter of transferring the section correctly.
I appreciate all the help you have provided.
Sincerely
Nicholas
On Mon, Nov 28, 2022 at 6:19 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Nov 27, 2022 at 10:22 PM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Petsc Users
>> I have a question about properly using PetscSection to assign state
>> variables to a DM. I have an existing DMPlex mesh distributed on 2
>> processors. My goal is to have state variables set to the cell centers. I
>> then want to call DMPlexDistribute, which I hope will balance the mesh
>> elements and hopefully transport the state variables to the hosting
>> processors as the cells are distributed to a different processor count or
>> simply just redistributing after doing mesh adaption.
>> Looking at the DMPlex User guide, I should be able to achieve this with a
>> single field section using SetDof and assigning the DOF to the points
>> corresponding to cells.
> Note that if you want several different fields, you can clone the DM
> first for this field
> call DMClone(dm,dmState,ierr)
> and use dmState in your calls below.
>> call DMPlexGetHeightStratum(dm,0,c0,c1,ierr)
>> call DMPlexGetChart(dm,p0,p1,ierr)
>> call PetscSectionCreate(PETSC_COMM_WORLD,section,ierr)
>> call PetscSectionSetNumFields(section,1,ierr) call
>> PetscSectionSetChart(section,p0,p1,ierr)
>> do i = c0, (c1-1)
>> call PetscSectionSetDof(section,i,nvar,ierr)
>> end do
>> call PetscSectionSetup(section,ierr)
>> call DMSetLocalSection(dm,section,ierr)
> In the loop, I would add a call to
> call PetscSectionSetFieldDof(section,i,0,nvar,ierr)
> This also puts in the field breakdown. It is not essential, but nicer.
>> From here, it looks like I can access and set the state vars using
>> call DMGetGlobalVector(dmplex,state,ierr)
>> call DMGetGlobalSection(dmplex,section,ierr)
>> call VecGetArrayF90(state,stateVec,ierr)
>> do i = c0, (c1-1)
>> call PetscSectionGetOffset(section,i,offset,ierr)
>> stateVec(offset:(offset+nvar))=state_i(:) !simplified assignment
>> end do
>> call VecRestoreArrayF90(state,stateVec,ierr)
>> call DMRestoreGlobalVector(dmplex,state,ierr)
>> To my understanding, I should be using Global vector since this is a pure
>> assignment operation and I don't need the ghost cells.
> Yes.
> But the behavior I am seeing isn't exactly what I'd expect.
>> To be honest, I'm somewhat unclear on a few things
>> 1) Should be using nvar fields with 1 DOF each or 1 field with nvar
>> DOFs or what the distinction between the two methods are?
> We have two divisions in a Section. A field can have a number of
> components. This is intended to model a vector or tensor field.
> Then a Section can have a number of fields, such as velocity and pressure
> for a Stokes problem. The division is mainly to help the
> user, so I would use the most natural one.
>> 2) Adding a print statement after the offset assignment I get (on rank 0
>> of 2)
>> cell 1 offset 0
>> cell 2 offset 18
>> cell 3 offset 36
>> which is expected and works but on rank 1 I get
>> cell 1 offset 9000
>> cell 2 offset 9018
>> cell 3 offset 9036
>> which isn't exactly what I would expect. Shouldn't the offsets reset at 0
>> for the next rank?
> The local and global sections hold different information. This is the
> source of the confusion. The local section does describe a local
> vector, and thus includes overlap or "ghost" dofs. The global section
> describes a global vector. However, it is intended to deliver
> global indices, and thus the offsets give back global indices. When you
> use VecGetArray*() you are getting out the local array, and
> thus you have to subtract the first index on this process. You can get
> that from
> VecGetOwnershipRange(v, &rstart, &rEnd);
> This is the same whether you are using DMDA or DMPlex or any other DM.
>> 3) Does calling DMPlexDistribute also distribute the section data
>> associated with the DOF, based on the description in DMPlexDistribute it
>> looks like it should?
> No. By default, DMPlexDistribute() only distributes coordinate data. I you
> want to distribute your field, it would look something like this:
> DMPlexDistribute(dm, 0, &sfDist, &dmDist);
> VecCreate(comm, &stateDist);
> VecSetDM(sateDist, dmDist);
> PetscSectionCreate(comm §ionDist);
> DMSetLocalSection(dmDist, sectionDist);
> DMPlexDistributeField(dmDist, sfDist, section, state, sectionDist,
> stateDist);
> We do this in src/dm/impls/plex/tests/ex36.c
> THanks,
> Matt
> I'd appreciate any insight into the specifics of this usage. I expect I
>> have a misconception on the local vs global section. Thank you.
>> Sincerely
>> Nicholas
>> Ph.D. Candidate
>> Computational Aeroscience Lab
>> University of Michigan
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221207/24eba5c0/attachment-0001.html>
