[petsc-users] About Preconditioner and MUMPS
Matthew Knepley
knepley at gmail.com
Tue Dec 6 07:56:28 CST 2022
On Tue, Dec 6, 2022 at 5:16 AM 김성익 <ksi2443 at gmail.com> wrote:
> Hello,
> I have some questions about pc and mumps_icntl.
> 1. What’s the difference between adopt preconditioner by code (for
> example, PetscCall(PCSetType(pc,PCLU)) and option -pc_type lu??
If you call KSPSetFromOptions(), then they are the same.
> And also, What’s the priority between code pcsettype and option -pc_type ??
PCSetType() will force the change. If you call KSPSetFromOptions() after
that, -pc_type will override the change.
2. When I tried to use METIS in MUMPS, I adopted metis by option (for
> example, -mat_mumps_icntl_7 5). In this situation, it is impossible to use
> metis without pc_type lu.
This is incorrect. You might still call PCSetType() if you want, but you
must call KSPSetFromOptions() after that.
> However, in my case pc type lu makes the performance poor. So I don’t want
> to use lu preconditioner. How can I do this?
This statement is incoherent. MUMPS is LU preconditioning, so if you use
MUMPS you are using LU.
Matt
> Thanks,
> Hyung Kim
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221206/e5a95fc6/attachment.html>
