[petsc-users] How to introduce external iterative solver into PETSc
袁煕 yuanxi at advancesoft.jp
Mon Dec 5 19:55:22 CST 2022
Dear Matt
It seems that I am in the wrong way!  I will retry following your example.
Thanks a lot!
 Yuan
2022年12月5日(月) 22:11 Matthew Knepley <knepley at gmail.com>:
> On Mon, Dec 5, 2022 at 3:08 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>> Dear PETSc developers,
>> I have my own linear solver and am trying to put it into PETSc as an
>> external solver.  Following the implementation of mumps, mkl_cpardiso,
>> supelu etc, I think I should do the follow:
>> 1.  Add my solver name into MatSolverType.
>> 2.  Register my solver by calling MatSolverTypeRegister
>> to let petsc record the existence of a new solver. The problem is that
>> the above external solvers are all direct solvers, and a MatFactorType
>> parameter should be set to indicate its factorization type, such as LU, QR,
>> or Cholesky. But my solver is an iterative one, that means I cannot specify
>> its MatFactorType. I wish to understand
>> 1. Am I doing it the right way? And if so
>> 2. How to set such parameters as MatFactorType,
>> lufactorsymbolic, lufactornumeric.
> This was a misunderstanding. If it is an iterative solver, you can follow
> the template for Jacobi:
> https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/jacobi/jacobi.c
> There are comments throughout this file showing you how to register your
> own preconditioner. You should not need to alter PETSc source.
> I have done this myself with the BAMG preconditioner.
>   Thanks,
>       Matt
>> Many thanks,
>> Yuan
>> Ph.D. in Solid Mechanics
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221206/40d06143/attachment.html>
