[petsc-users] How to introduce external iterative solver into PETSc
Matthew Knepley
knepley at gmail.com
Mon Dec 5 07:11:07 CST 2022
On Mon, Dec 5, 2022 at 3:08 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
> Dear PETSc developers,
> I have my own linear solver and am trying to put it into PETSc as an
> external solver. Following the implementation of mumps, mkl_cpardiso,
> supelu etc, I think I should do the follow:
> 1. Add my solver name into MatSolverType.
> 2. Register my solver by calling MatSolverTypeRegister
> to let petsc record the existence of a new solver. The problem is that the
> above external solvers are all direct solvers, and a MatFactorType
> parameter should be set to indicate its factorization type, such as LU, QR,
> or Cholesky. But my solver is an iterative one, that means I cannot specify
> its MatFactorType. I wish to understand
> 1. Am I doing it the right way? And if so
> 2. How to set such parameters as MatFactorType,
> lufactorsymbolic, lufactornumeric.
This was a misunderstanding. If it is an iterative solver, you can follow
the template for Jacobi:
https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/jacobi/jacobi.c
There are comments throughout this file showing you how to register your
own preconditioner. You should not need to alter PETSc source.
I have done this myself with the BAMG preconditioner.
Matt
> Many thanks,
> Yuan
> Ph.D. in Solid Mechanics
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221205/af1aa619/attachment.html>
