[petsc-users] Installation With MSYS2 and MinGW Compilers
Singh, Rajesh K rajesh.singh at pnnl.gov
Mon Dec 5 14:50:02 CST 2022
Hi Pierre,
Thank you so much for prompt response. I will run FORTRAN based code with PETSc. Therefore I guess I will need Fortran binding.
Regards
Rajesh
Sent: Monday, December 5, 2022 12:41 PM
To: Singh, Rajesh K <rajesh.singh at pnnl.gov>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Installation With MSYS2 and MinGW Compilers
Check twice before you click! This email originated from outside PNNL.
Hello Rajesh,
Do you need Fortran bindings?
Otherwise, ./configure --with-fortran-bindings=0 should do the trick.
Sowing compilation is broken with MinGW compiler.
If you need Fortran bindings, we could try to fix it.
Pierre
On 5 Dec 2022, at 9:22 PM, Singh, Rajesh K via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Dear All:
I am having diffisulty to install PETSC on the window system. I went through the the steps esplained in the web site and got following error.
<image001.png>
Help for resolving this issue would be really appricaited.
Rajesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221205/1f2acab8/attachment.html>
