[petsc-users] Installation With MSYS2 and MinGW Compilers
Pierre Jolivet
pierre at joliv.et
Mon Dec 5 14:40:39 CST 2022
Hello Rajesh,
Do you need Fortran bindings?
Otherwise, ./configure --with-fortran-bindings=0 should do the trick.
Sowing compilation is broken with MinGW compiler.
If you need Fortran bindings, we could try to fix it.
Pierre
> On 5 Dec 2022, at 9:22 PM, Singh, Rajesh K via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Dear All:
> I am having diffisulty to install PETSC on the window system. I went through the the steps esplained in the web site and got following error.
> <image001.png>
> Help for resolving this issue would be really appricaited.
> Thanks,
> Rajesh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221205/633d2d68/attachment.html>
