[petsc-users] DMPlex Traversal
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Fri Dec 2 06:02:35 CST 2022
Hi
Currently, I am just trying to replace the mesh management in an existing
code using DMPlex. So I am distributing the DMPlex and then passing the
mesh information and translating the PetscSF information off into the
existing MPI solver. So I think using the cone and support should be fine.
It does happen repeatedly during the run time but with a different
distribution each time so I think GetAdjacency will cover my use case.
Thank you for the clarification
Sincerely
Nicholas
On Fri, Dec 2, 2022 at 6:49 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Dec 2, 2022 at 5:16 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Petsc Users
>> I have become familiar with usage of DMPlexGet(Restore)TransitiveClosure
>> as well as general traversal of the graph using DMPlexGetCone and
>> GetSupport.
>> I was wondering if there is a more trivial way to get access to adjacent
>> points of the same Stratum.
>> For example, I have an 2D mesh. I have identified the point value of a
>> cell of interest and I would like to get the point value of the surrounding
>> cells. So far the way I get that is I descend a level using GetCone and
>> then for each constituent point (face in this case) call GetSupport (which
>> yields the adjacent cell and the original cell) and discard the original
>> cell.
>> Is there a direct function call that achieves this? I've looked a bit
>> into the Adjacency commands but they seem to be more for variable influence
>> (FV or FE) and using them seems to throw an error.
> It is important to lay out why you want to do this, because it influences
> the choice of implementation.
> If you just want to discover topology, then doing it using Cone and
> Support is fine. This is what GetAdjacency is doing underneath.
> However, if you want to repeatedly do this, which most people do for
> dof traversal, then you should make an index. There are two cases
> of this in Plexx right now, but we could easily have more. GetAdjacency is
> used to construct the sparsity pattern for the Jacobian, which
> serves as an index. Also GetClosure is used to construct the closure index
> which we use when setting values since this is a common
> operation in FE.
> What do you want to do with this?
> Thanks,
> Matt
>> Sincerely
>> Nicholas
>> Ph.D. Candidate
>> Computational Aeroscience Lab
>> University of Michigan
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221202/0a7cffcb/attachment.html>
