[petsc-users] locate DMSwarm particles with respect to a background DMDA mesh
Matteo Semplice
matteo.semplice at uninsubria.it
Fri Dec 2 05:48:41 CST 2022
Hi.
I am sorry to take this up again, but further tests show that it's not
right yet.
Il 04/11/22 12:48, Matthew Knepley ha scritto:
> On Fri, Nov 4, 2022 at 7:46 AM Matteo Semplice
> <matteo.semplice at uninsubria.it> wrote:
> On 04/11/2022 02:43, Matthew Knepley wrote:
>> On Thu, Nov 3, 2022 at 8:36 PM Matthew Knepley
>> <knepley at gmail.com> wrote:
>> On Thu, Oct 27, 2022 at 11:57 AM Semplice Matteo
>> Dear Petsc developers,
>> I am trying to use a DMSwarm to locate a cloud of points
>> with respect to a background mesh. In the real
>> application the points will be loaded from disk, but I
>> have created a small demo in which
>> * each processor creates Npart particles, all within
>> the domain covered by the mesh, but not all in the
>> local portion of the mesh
>> * migrate the particles
>> After migration most particles are not any more in the
>> DMSwarm (how many and which ones seems to depend on the
>> number of cpus, but it never happens that all particle
>> survive the migration process).
>> I am clearly missing some step, since I'd expect that a
>> DMDA would be able to locate particles without the need
>> to go through a DMShell as it is done in
>> src/dm/tutorials/swarm_ex3.c.html
>> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpetsc.org%2Fmain%2Fsrc%2Fdm%2Ftutorials%2Fswarm_ex3.c.html&data=05%7C01%7Cmatteo.semplice%40uninsubria.it%7C60177cfedb2948f480d008dabe5a7e7a%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C638031593122164987%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=43%2FIiK5P%2FhBStaVKhonw0p7wb87L8jqf2MheL9E1gR0%3D&reserved=0>
>> I attach my demo code.
>> Could someone give me a hint?
>> Thanks for sending this. I found the problem. Someone has
>> some overly fancy code inside DMDA to figure out the local
>> bounding box from the coordinates.
>> It is broken for DM_BOUNDARY_GHOSTED, but we never tested
>> with this. I will fix it.
>> Okay, I think this fix is correct
>> https://gitlab.com/petsc/petsc/-/merge_requests/5802
>> <https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.com%2Fpetsc%2Fpetsc%2F-%2Fmerge_requests%2F5802&data=05%7C01%7Cmatteo.semplice%40uninsubria.it%7C60177cfedb2948f480d008dabe5a7e7a%7C9252ed8bdffc401c86ca6237da9991fa%7C0%7C0%7C638031593122164987%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=trNMoF9qIT91tBwkyatWdl7%2BB0Jy0AtJdsL8oYmN7sU%3D&reserved=0>
>> I incorporated your test as src/dm/impls/da/tests/ex1.c. Can you
>> take a look and see if this fixes your issue?
> Yes, we have tested 2d and 3d, with various combinations of
> DM_BOUNDARY_* along different directions and it works like a charm.
> On a side note, neither DMSwarmViewXDMF nor DMSwarmMigrate seem to
> be implemented for 1d: I get
> [0]PETSC ERROR: No support for this operation for this object
> type[0]PETSC ERROR: Support not provided for 1D
> However, currently I have no need for this feature.
> Finally, if the test is meant to stay in the source, you may
> remove the call to DMSwarmRegisterPetscDatatypeField as in the
> attached patch.
> Thanks a lot!!
> Thanks! Glad it works.
> Matt
There are still problems when not using 1,2 or 4 cpus. Any other number
of cpus that I've tested does not work corectly.
I have modified src/dm/impls/da/tests/ex1.c to show the problem (see
attached patch). In particular, I have introduced a -Nx option to allow
grid sizes higher than the standard 4x4 and also suppressed by default
particle coordinates output (but there's an option -part_view that
recreates the old behaviour). Here's the output on my machine:
$ mpirun -np 1 ./da_test_ex1 -Nx 40
Total of 8 particles
... calling DMSwarmMigrate ...
$ mpirun -np 2 ./da_test_ex1 -Nx 40
Total of 16 particles
$ mpirun -np 4 ./da_test_ex1 -Nx 40
Total of 32 particles
$ mpirun -np 3 ./da_test_ex1 -Nx 40
Total of 24 particles
Total of 22 particles
$ mpirun -oversubscribe -np 5 ./da_test_ex1 -Nx 40
Total of 40 particles
$mpirun -oversubscribe -np 8 ./da_test_ex1 -Nx 40
Total of 64 particles
Total of 46 particles
As you see, only 1,2,4 cpus do not lose particles.
(The test could be easily modified to return nTotPart/predistribution -
nTotPart/postdistribution so that it will have a nonzero exit code in
case it loses particles)
Best
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221202/40bb1cfd/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221202/40bb1cfd/attachment-0001.bin>
