[petsc-users] DMLabel Synchronize
    Matthew Knepley
    knepley at gmail.com
    Wed Aug 31 06:44:54 CDT 2022
On Tue, Aug 30, 2022 at 6:37 PM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi
> Thanks for all the help. I'm looking to tag several cells based on metrics
> occurring at run time. In addition to the metric-defined cells I also want
> to label the surrounding cells. This is no problem as I can traverse the
> DMPlex chart to get the neighboring cells. The issue only arises if an
> identified cell is on a partition boundary. this leads to the neighbor
> cell in the overlap halo being tagged. However, the root cell on the
> adjacent partition is not tagged. Is there a built-in way to synchronize
> the labels from the leafs to the roots?
> Right now, I iterate through the root and leaf cells of each processor,
> but it is somewhat wasteful as I don't see a way for the root cell
> partition to know if a corresponding leaf cell label value without
> communicating it first.
What I think you want is this:
  https://petsc.org/main/docs/manualpages/DMLabel/DMLabelPropagateBegin/
I use this to do the same kind of labeling I think. It is setup to allow
multiple rounds,
so that you can use the communicated labeling to continue on the new rank.
Will this work?
     Matt
> Thanks
> Nicholas
> Ph.D. Candidate
> Computational Aeroscience Lab
> University of Michigan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220831/503fa8af/attachment.html>
