[petsc-users] Preallocating a matrix with the d_nnz and o_nnz arrays
Zhang, Hong
hzhang at mcs.anl.gov
Mon Aug 22 11:03:31 CDT 2022
See https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation
MatMPIAIJSetPreallocation - PETSc<https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html#MatMPIAIJSetPreallocation>
MatMPIAIJSetPreallocation Preallocates memory for a sparse parallel matrix in AIJ format (the default parallel PETSc format). For good matrix assembly performance the user should preallocate the matrix storage by setting the parameters d_nz (or d_nnz) and o_nz (or o_nnz).
petsc.org
if you use mpiaij matrix.
Hong
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Patrick Alken <patrick.alken at geomag.info>
Sent: Monday, August 22, 2022 10:56 AM
To: petsc-users <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Preallocating a matrix with the d_nnz and o_nnz arrays
I am looping through all the non-zero elements of my matrix to count the
diagonal and off-diagonal terms in order to pre-allocate the matrix.
However, what is the criteria for knowing if a given element is in the
diagonal portion or off-diagonal portion? It seems that it will depend
on row, column, and also processor. I was doing something like this:
MatGetLocalSize(A, &m, &n);
MatGetOwnershipRange(A, &first, &last);
for (i = first; i < last; ++i) {
for (j = 0; j < N; ++j) {
if (abs(i - j) < m)
++d_nnz[i - first];
else
++o_nnz[i - first];
However, the criteria: abs(i - j) < m is not correct. I think the
correct criteria will include the processor number also. Does anyone
know the correct criteria to use?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220822/b356a284/attachment.html>
