[petsc-users] Preallocating a matrix with the d_nnz and o_nnz arrays
Patrick Alken
patrick.alken at geomag.info
Mon Aug 22 10:56:34 CDT 2022
I am looping through all the non-zero elements of my matrix to count the
diagonal and off-diagonal terms in order to pre-allocate the matrix.
However, what is the criteria for knowing if a given element is in the
diagonal portion or off-diagonal portion? It seems that it will depend
on row, column, and also processor. I was doing something like this:
MatGetLocalSize(A, &m, &n);
MatGetOwnershipRange(A, &first, &last);
for (i = first; i < last; ++i) {
for (j = 0; j < N; ++j) {
if (abs(i - j) < m)
++d_nnz[i - first];
else
++o_nnz[i - first];
However, the criteria: abs(i - j) < m is not correct. I think the
correct criteria will include the processor number also. Does anyone
know the correct criteria to use?
