[petsc-users] Parallel assembly of a matrix problem
Mark Adams mfadams at lbl.gov
Mon Aug 15 05:29:10 CDT 2022
You might need to fix this:
if (i - j < m)
to
if (i - j < m && i - j >= 0)
On Mon, Aug 15, 2022 at 12:12 AM Patrick Alken <patrick.alken at geomag.info>
wrote:
> I am trying to assemble a matrix in parallel in Petsc, and it is working
> for 1 processor, but when I try running it with 2 processors I get
> errors like the following:
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Argument out of range
> [1]PETSC ERROR: New nonzero at (0,207) caused a malloc
> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
> off this check
> [1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.17.4, unknown
> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() at
> /data/palken/petsc/src/mat/impls/aij/mpi/mpiaij.c:506
> and then many MatSetValues errors follow.
> I have attached a minimal working example and a Makefile. My code does
> depend on the GSL library also. I think there must be a problem in how I
> set up the d_nnz and o_nnz arrays for the MatMPIAIJSetPreallocation()
> function (lines 211-235 of mwe.c).
> I am building a matrix using radial basis functions with compact
> support, so the matrix entries are zero when ||Xi - Xj|| >= c, where c
> is the RBF shape parameter. This is accounted for on line 224 and 254 of
> the code. As far as I can tell I am consistent in the way I define the
> nnz arrays and the way I call MatSetValues, so I don't know why Petsc
> would need to malloc additional memory during the assembly process.
> Any pointers would be greatly appreciated.
> Patrick
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220815/88c4d8b5/attachment.html>
