[petsc-users] Configure error with PETSc 3.17.4 on Ubuntu 22.04
David Knezevic david.knezevic at akselos.com
Fri Aug 12 12:32:10 CDT 2022
Regarding 1.: We're using --download-mumps, so this is the mumps that was
installed during config. There was no mumps build prior to that. Does that
change anything?
Regarding 2.: We need --with-clanguage=cxx since we're also using an
external C++ library (libMesh). We've been using --with-clanguage=cxx in
PETSc with libMesh for years...
On Fri, Aug 12, 2022 at 1:24 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Aug 12, 2022 at 1:14 PM David Knezevic via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> I get a configure error when building PETSc 3.17.4 on Ubuntu 22.04. The
>> configure.log is attached.
>> This error seems to only occur when we use --with-clanguage=cxx. We need
>> to use that object when building with complex numbers.
>> Guidance on how to resolve this would be most appreciated.
> 1. I think your existing MUMPS build is incompatible (but it is hard for
> us to tell). Remove it
>   rm -rf $PETSC_DIR/$PETSC_ARCH/externalpackages/git.mumps
> and reconfigure
> 2. You can also use C99 for complex numbers, but your application code
> might already be using C++.
>   Thanks,
>      Matt
>> Thanks,
>> David
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220812/7d6cf591/attachment.html>
