[petsc-users] Configure error with PETSc 3.17.4 on Ubuntu 22.04
Fri Aug 12 12:23:59 CDT 2022
On Fri, Aug 12, 2022 at 1:14 PM David Knezevic via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I get a configure error when building PETSc 3.17.4 on Ubuntu 22.04. The
> configure.log is attached.
> This error seems to only occur when we use --with-clanguage=cxx. We need
> to use that object when building with complex numbers.
> Guidance on how to resolve this would be most appreciated.
1. I think your existing MUMPS build is incompatible (but it is hard for us
to tell). Remove it
  rm -rf $PETSC_DIR/$PETSC_ARCH/externalpackages/git.mumps
and reconfigure
2. You can also use C99 for complex numbers, but your application code
might already be using C++.
     Matt
> Thanks,
> David
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220812/6c74aae3/attachment.html>
