[petsc-users] DMPlex total point counts
Nicholas Arnold-Medabalimi
narnoldm at umich.edu
Mon Aug 8 10:56:21 CDT 2022
Thanks, this helped a great deal.
I wondered if there is any issue in using the IS generated by
DMPlexGetCellNumbering to count the cells instead? It looks like the IS
values will be -(globalID+1) if they are not on the local processor, so I
just count negative values instead of having to check the SF.
Sincerely
Nicholas
On Wed, Aug 3, 2022 at 10:33 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Aug 2, 2022 at 4:00 PM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi
>> Currently, in my distributed DMPlex object, every so often, I want to
>> look at total cell counts. To do this in my current implementation, I get
>> the cell stratum from the DMplex and search through the PetscSF to remove
>> any overlapped (not owned) cells and then reduce over all the ranks to get
>> the total cell count. Is there a more graceful way of doing this already
>> built into DM?
> If all you want is the global cell count, this is probably the easiest
> way. If you want a global numbering, you can use
> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetCellNumbering/
> Thanks,
> Matt
>> Sincerely
>> Nicholas
>> Ph.D. Candidate
>> Computational Aeroscience Lab
>> University of Michigan
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220808/2911a9d3/attachment.html>
