[petsc-users] DMPlex total point counts
Matthew Knepley
knepley at gmail.com
Wed Aug 3 09:32:54 CDT 2022
On Tue, Aug 2, 2022 at 4:00 PM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi
> Currently, in my distributed DMPlex object, every so often, I want to look
> at total cell counts. To do this in my current implementation, I get the
> cell stratum from the DMplex and search through the PetscSF to remove any
> overlapped (not owned) cells and then reduce over all the ranks to get the
> total cell count. Is there a more graceful way of doing this already built
> into DM?
If all you want is the global cell count, this is probably the easiest way.
If you want a global numbering, you can use
https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetCellNumbering/
Matt
> Sincerely
> Nicholas
> Ph.D. Candidate
> Computational Aeroscience Lab
> University of Michigan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220803/f3cb2012/attachment.html>
