[petsc-users] Combining DMDA and DMStag
Patrick Sanan patrick.sanan at gmail.com
Fri Apr 22 10:04:39 CDT 2022
Am Fr., 22. Apr. 2022 um 16:04 Uhr schrieb Barry Smith <bsmith at petsc.dev>:
>    We would need more details as to exactly what goes wrong to determine
> any kind of fix; my guess would be that the layout of the velocity vectors
> and temperature vectors is slightly different since the DMDA uses nelx+1
> while the stag uses nelx and may split things up slightly differently in
> parallel. You could try very small problems with say 2 or 4 ranks and put
> known values into the vectors and look at the ghost point update locations
> and exact locations in the local and global vectors to make sure everything
> is where you expect it to be.
>   There is also the possibility of using a DMStag for the temperature
> instead of DMDA since DMDA provides essentially a subset of the
> functionality of DMDA to get a more consistent layout of the unknowns in
> the two vectors.
This was going to be my first suggestion as well - one way to ensure
compatibility would be to use DMStag for everything. E.g. you could create
your temperature DMStag with only vertex/corner (dof30 degrees of freedom,
and then create one or more a "compatible" DMStags (same elements on each
MPI rank) for your other fields, using DMStagCreateCompatibleDMStag() .
  Finally, one could use a single DMStag with all the unknowns but treat
> subvectors of the unknowns differently in your discretization and solve
> process. So assign velocity values (I guess) to the cell faces and
> temperature to the cell vertices, this will give consistent parallel
> decomposition of values but you will have to manage the fact that the
> unknowns are interlaced into a single vector so your solver portions of the
> code may need to "pull" out appropriate subvectors.
>   Barry
> On Apr 22, 2022, at 9:45 AM, Carl-Johan Thore <carl-johan.thore at liu.se>
> wrote:
> Hi!
> I'm working on a convection-diffusion heat transfer problem. The
> temperature
> is discretized using standard Q1 elements and a DMDA. The flow is modelled
> using a stabilized Q1-Q0 method for which DMStag seemed like a good
> choice. The codes for the temperature
> and flow work fine separately (both in serial and parallel), but when
> combined and running
> in parallel, a problem sometimes arises in the assembly of the thermal
> system matrix.
> Here’s a rough sketch of the combined code:
> // Create dmda for thermal problem and dmstag for flow problem
> DMDACreate3d(PETSC_COMM_WORLD, bx, by, bz, DMDA_STENCIL_BOX, nelx+1,
> nely+1, nelz+1, PETSC_DECIDE, PETSC_DECIDE, PETSC_DECIDE,
>                 1, stencilWidth, 0, 0, 0,
> &dmthermal);
>> // A bit of code to adjust Lx,Ly,Lz so that dmthermal and dmflow are
> compatible in the sense of having the same
> // local elements
>> DMStagCreate3d(PETSC_COMM_WORLD, bx, by, bz, nelx, nely, nelz, md,nd,pd,
> 3,0,0,0,DMSTAG_STENCIL_BOX,stencilWidth,Lx,Ly,Lz,&dmflow);
> PetscInt edofT[8];          // 8-noded element with 1 temp DOF per node
> DMStagStencil edofF[24];       // 8 nodes with 3 velocity DOFs each
> // Assemble thermal system matrix K
> for (PetscInt e=0 ...)   // Loop over local elements
> // Populate edofF, edofT
>                              // Get element velocities in ue from local
> velocity vector uloc
> DMStagVecGetValuesStencil(dmflow,uloc,24,edof,ue);
>                              Ke = Ke_diffusion + Ke_convection(ue)
>                              MatSetValuesLocal(K, 8, edofT, 8, edofT, Ke,
> ADD_VALUES);
> This always works fine in serial, but depending on the mesh and the number
> of ranks,
> we don't always get the correct values in the element velocity vector ue.
> I suspect
> this has something to do with the ordering of the elements and/or the
> DOFs, because
> the elements in the global velocity vector are always the same but their
> order may change
> (judging from the output of VecView at least).
> Is it possible to ensure compatibility between the dm:s, or find some kind
> of mapping
> between them, so that something along the lines of the code above always
> works?
> Kind regards,
> Carl-Johan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220422/81fc1c44/attachment-0001.html>
